I've it coming on a container (someone (house) moving back to Ireland - where I am); Waiting another month or so before I get my hands on it and then will see how it fits etc.. can report back then. Found via expats-in-Australia (FB group) so might be an avenue to try
I’m running the ph12650 and the phb100p.
I chose to run with inside the frame so sliders were easier and the exhaust is less exposed to damage offroad.
My CRX headers are coming up on six years old. I still love the exhaust sound on startup. The only issue was early on with the nuts and bolts where the 3-1 pipes were connected. The lock washers lost their tension due to the heat and vibrated loose. This is above the section of flex pipe. I replace the four with longer bolts and did double nut. Bottom nut flanged with the ridges to lock instead of a washer. Supercharger caused a little surgery to be needed as the #3 pipe stuck up too high.
Thanks for this! I have the CXRacing system on my 96. I had to order a new downpipe from them because one of the flex joints developed a huge leak. I had the new downpipe installed by a shop that was doing some work to my AC. On my first long road trip, I developed a leak at the flange connections between the headers and downpipe and it melted my washer bottle that's relocated by the firewall. When I looked under the fender, one of the flange bolts was missing the nut on the bottomside. I bought some nuts and bolts to get back home and took it back to the shop that installed it. They replaced the gaskets and installed new bolts and nuts. I picked it up and within 15 miles I had a leak again. It looks like when 1 flange is flush, the other is off a few degrees but you would think the "flex joints" would allow them to both mate up flush. I'm going to try the double nut trick to see if I can make it work.
Been a couple of months since I used the double nut trick and everything seems to be holding! I haven't been on a long road trip but plenty of highway driving and a short 2 hour trip and no leaks. I think I'm free to reinstall my washer bottle!
I would say improved seat of the pants performance but not much MPG improvement. I went with a 3" custom exhaust and kept a single cat. Intermittent CEL for lean condition. Currently no CEL!
CXRacing headers will delete your EGR! There is no channel cut for the #6 exhaust to port to the EGR.
CXR vs stock, cursor at #6.
