I just got one of these for $44 from
Amazon. It's firmware version #297. There is a lot of confusion about which version of this radio you get when you order. UV-5RA and UV-5R+ appear to be the same radio, with the same firmware, in a slightly different case. As of just now, they are the current versions. I got the UV-5RA from Etekcity for what it's worth.
So far, this seems to be a really good radio for a really small price. You are getting the features of a $200 HT for $40.
You have to program it with CHIRP. I've been a ham for almost 8 years and could not figure out the keyboard programming. The manual that comes with it is basically worthless. CHIRP however is the bomb for this radio, as is the Miklor site.
The antenna it comes with is OK, I have a couple of
ebay specials on the way to see if it makes a difference.
The battery life is good and high cap batteries are available for $20 or so. Batteries for the UV-5RA just became available and I have one coming from Hong Kong. We'll see how that works out. Unfortunately you need to think about what radio you have to get the proper spare battery as the minor case differences can prevent some from fitting the version you might have.
Overall, it's a decent radio, that allows a whole lot of illegal activity. For instance, if you program the NOAA weather channels, which are extremely useful while out in the wild, you can't turn off the transmit function. So if you were careless, and hit the PTT, it would transmit on the weather frequencies. This is not to mention the FRS/GMRS/MURS transmission possibilities.
There are a couple of issues:
1-The antenna is a SMA female which is a "standard" only in Chinese radios. It's easy to work around, but you do need to think about it.
2-It isn't weather proof like most name brand HTs.
3-Forget about keyboard programming, so you need to buy a $10 programming cable. Not a big deal, but it adds 25% to the price of the radio. There are some cable driver issues you need to work through too.
4-Charger works but is junk. Unfortunately it no longer has the Chinglish label. I wanted to make the Chareto mistake and sadly, it is no longer a feature of this radio.
If you buy one of these, take the time to work through CHIRP. It makes programming this radio fun and increases it's usefulness dramatically. The latest firmware I have seen is the 297. If you buy from Etekcity or Sain Store on
Amazon, you get the latest version. Interestingly, if you get the programming cable ($9) on
Amazon, there are no driver issues that I could detect. The driver that windows loads automatically, works fine.
Just for reference, I was working the Mt Diablo repeater today from my driveway, which is 90 miles or so. Not bad for a $40 HT with the stock antenna.
