LOL - I would certainly hope so anyway .
Sarge
Sarge
Yes, the front bolts are all the same length. The tower bolts and frt cover bolts are mixed up. Might also be some of the bolts for the T-case PTO sidecover.
If that is a trick for removing shifter, what is the not-tricky way to remove shifter?
How did you remove it before?
I'm unaware of an alternative method.![]()
From the picture, it looks like twist right to remove and left to re insert? I've heard that it could be either way (different part was used) with no rhyme or reason to indicate which Sent from my iPhone using IH8MUD at 85mph in an FJ40
Output shaft area needs to be in this order:
- Tranny
- Tranny output bearing
- Output shaft short spacer (the one just above)
- transfer case
- inside the transfer case - T-case drive gear,
- inside transfer case, spacer or PTO gear
- output shaft tcase bearing
- yet another spacer or rear PTO drive
- washers and nut
- tail cone
Is this right?
VV in response to your request on my thread - does this help? Top of photo is top of PTO window Although the transfer case looks different in some respects (look at he webbing pattern, and no internal bolts that i can see)? I think I have a H42.
