- Thread starter
- #181
Congrats! So what was the issue preventing everything from lining up? It looks great.
Semper victorius![]()
Your going to be one bundles of nerves the first time you ever drive that thing given the depth of rebuilding everything , lol ....
Sarge
Hi Vae,
Here another H42 than needs a freshen up. (are you volunteering?)This one was overhauled in 1988 and has been in continuous hard service ever since. The output shaft was repaired with welding and regrinding the splines in with a small off hand grinder. i am very interested to see how well it held up. Will post some photos when the transfer case is off the trans.
Here's a picture of the release bearing with back yard grease job and the cover tack welded on after it was taken apart. This was back in the day when I didn't think FJ40's would ever be desirable like they are now. It worked for 26 years without missing a beat and no unnecessary noises. Mr T really did build them to be repaired in imaginative ways.
Your Chinese bearing will still be going strong long after you are pushing -up daisies.
Good job on finishing the H42.
Thanks jb
Hi Vae,
The shorter bolts may be from the shifter tower. There are different lengths there.
As far as I know the 7 front retainer bolts are all the same length 25mm long
The shift tower has 2 bolts 25mm long and 4 bolts 20mm long all the bolts are marked with a 6 on the head.
Don't like the use of RTV on the gaskets. In my opinion it is not needed and just messes up and other wise clean job. You could take a blade and carefully peel it off when it has set. Haven't had a H42 and transfer case leak when that are put together with new gaskets. I have use RTV sparingly on old gaskets. If you get a lot of squeeze out you are putting too much on. There are some bolts you need a little thread sealant on because they are open through the case rather than blind holes.
Front retainer and the transfer case case long bolts especially.
When you come to fill it with 80-90 oil you can pour it through the shift tower and watch the fill plug for a level, much easier than using the fill hole.
I bet you are glad to be finished that part. How are the plans for your shop coming along?
Thanks jb
I've rebuilt a few H41/2s.
The best method for removing bearings I have found is...
Lay a piece of tube steel across the bearings and tack weld the bar to the bearings. After taping shafts to make sure no slag sticks to them.
Make sure the tube sticks further out past the side of the transmission so you can tap it with a hammer. You can have all of the bearings off with in a few minutes. The heck with pullers in this case, I've had them exploded on me.
Good luck,
-Al![]()
