Media GX470 Wheel/Tire/Lift Picture Combination Thread (6 Viewers)
Photo/Video/Audio threads
255/80 R17 Cooper Discoverer S/T MAXX
~2.5 lift wit Bilstein and OME springs
Freedom Off Road Tubular upper control arms
I'm getting a bit of rubbing on the passenger side body mount. My caster is 4+
No spare fitment issues with the JW mount.
@journey_gx470 on instagram
Eibach Pro Truck 1, SPC UCAs, 285/70-17 Ridge Grappler Cs, FJ Cruiser 7.5” wide wheel, a good amount of cutting of plastic.
LC120 3.0l Diesel (aparently lighter than the GX)
Toyo Open Country AT3 265-70-17
Dobinsons: Front - GS59-221 & C59-302, Rear - GS59-701 & C59-327
Pre Lift: Front - 745mm, Rear 765mm
Post Lift: Front - 790mm, Rear 830mm (it had sagged quite a bit)
Measured bottom of wheel to centre of arch. (mm to inch conversion - divide by 25.4)
Photos show loads from Empty to 300kg...
Its a bit higher than I thought it would be. Will give it 6 months to properly bed in.
Adjustable panhard will not solve your issue other than to recenter at ride height but then the axle will move farther left and right during travel. You want an EIMkeith panhard correction kit and you can use your stock panhard still
Adjustable panhard will not solve your issue other than to recenter at ride height but then the axle will move far move left and right during travel. You want an EIMkeith panhard correction kit and you can use your stock panhard still
Awesome I will definitely look into that thank u. How about adjustable sway bar links? Just wanting to do a 2inch lift
You want to swaybar to be flat for it to work best. I think 2nd gen 4runner rear links work. They're the same as the GX but longer
That’s great to know. Hopefully I can get all the parts correct before ordering. Dont want to spend $300 on sway bar links if there is a cheaper option
If you or a friend have access to a welder you can DIY a set if adjustable rear links for around $60. See my build thread if you are interested. I used new Moog links, some coupling nuts, and allthread.
06 with Amazon special $175 wheels (-12mm offset) paired with 275/70 Wildpeak ATs
About a 2.5in lift from Bilstein 6112 shocks and spring.
JBA offroad Upper Control arms.
Stock lower control arms
Rear currently on stock bags, at N setting show in photo
I haven’t pulled the trigger on any specific lift kit yet, looking at eibach on a metal tech conversion with the cone isolators, or OME, dobinsons and spending a bit more money. I am assuming that I need to modify the links and get new ucas no matter what I go with. That would be great if I can manage to do that my family friend has a mig welder and is a pretty skilled mechanic but he’s never done a lift kit so they’re kinda second guessing it. Might have to take it to the shop. I can definitely do the conversion to stock height coils but not sure about a lift because I’m not experienced in that either. I really appreciate the help and I will definitely check out your build! My main concern is if my lift will be out of wack with it purchasing. Going to post or send you a list of what I’m looking at.
35x10.50r17 Kenda RT.
It fits in my normal 7' garage with a plenty of clearance to spare. Roof rack removed.
TRD off road wheels with 1" spacer = -10 offset. 3" lift, SPC UCA at E setting, Superpro quad offset LCA bushing to bring the LCA even further forward. No BMC yet, but looks it it need a little trim. Flex test in the garage shows it rub the pinch weld but did not touch the body mount. It might when reversing under heavy torque. Would need to relocate washer bottle as it would definitely get squashed at full flex.
