Media GX470 Wheel/Tire/Lift Picture Combination Thread (14 Viewers)
Photo/Video/Audio threads
OME Mediums w/ 5100 Front and 5160 Rear
KMC 717 17x8.5 +0
Patagonia M/T 285/70/17
"Skinnies!"
Tires: 235/80/17
Wheels: Stock
Spacers: 1.5in
Lift: None
Mods: Metaltech rear coil conversion kit.
Slight rubbing at full tilt, just barely though...
"Skinnies!"
Tires: 235/80/17
Wheels: Stock
Spacers: 1.5in
Lift: None
Here is a pic of the front fender liner rubbing from 235/80/17 on stock rims plus 1.5in spacer..😜
Dobinsons IMS 3" lift (front and rear)
KN Overlander Spec A 17" x 8.5" wheels
Nitto Terra Grappler G2s 285/70/17s
Custom bumper and sliders by a local fabricator
No actions shots yet. Just got the alignment done but not perfected yet. Have Dobinsons rear lower control arms on order and also going to drive it a couple of weeks and let the suspension settle a little. Then we'll do another alignment. Waiting on the steering wheel to be perfectly straight again so I can try the ZPC to get rid of this damn blinking "Off" light.
Little update to my GX.
Enkei RPT1 17x9 0 offset
Cooper Evolution MT 285/70/17
Spidertrax 1.25" spacers
Eibach Pro Truck Lift kit
JBA UCA
Looks great!
Any pics of how you mounted the Ironman awning to your OEM rack/crossbars? I'd like to get the same awning but haven't figured out a good mounting solution quite yet.
Looks great!
Thank you!
I’m using the Rago awning brackets. Note that the nuts they provided were a bit larger than the GX rail openings. Takes a bit of massaging and a few choice cuss words.
thanks! Surprised I haven’t seen your GX around. Looks good!
I've been working in Eastern WA for a while now, but I come back from time to time. If you see me I'll have a swingout rear bumper on within the next few weeks!
2003 GX470
Front- OME N140S shocks with 2885 springs.
Rear- OME 60004 Nitrocharger shocks with 2895 springs
FN Wheels FX Pro with 275/70/17 BFG KO2's
I really like these wheels and tires. I looked up the FN wheels. They say they are a 0mm offset. Did you use a spacer or did they have a different offset when you bought them? Or are these just 0mm? Thanks!
Sam
