Media GX470 Wheel/Tire/Lift Picture Combination Thread
Photo/Video/Audio threads
Did you have to do a bmc also? I have a set of -38 ray10 on order plus "33 ko2. Just wondering how much cutting needs to be done
Yes. I did. I have not yet done the lower A arm trick. Right now it only rubs on extreme compression on tight turns. Once I move my wheel forward I don’t think I’ll have any problems in the rear at all. May have to chop a little more of my bumper though.
Excuse my ignorance but what's the lower A arm trick? Is it the same as adding castor to move the wheel forward?
Figured I would finally post some photos of my GX. This forum was so useful when I did my work last summer. Thank you all.
2006 GX470
- Front Suspension: Bilstein B8 6112 Lift Kit (46-227287), set to circlip location #3.
- Rear Shocks: Bilstein B8 5100 (33-187174)
- Rear Springs: Bilstein B12 special (36-281824)
- Rear Coil Conversion Kit: Metal Tech Stage 1. Purchased new OEM spring seats from online Toyota dealer.
- Wheels/Tires: 2019 4runner TRD Off Road Road wheels with 265/70/17 Bridgestone Dueler HT 684II tires. Wheels/tires came as package as they were take-offs from a brand new 4runner at the time. Waiting for tires to wear out. When they do I am going to go with Cooper AT3 4S or Goodyear Wrangler All Terrain Adventure w/Kevlar.
I have put on 10,000 miles since I completed the work in June 2020. This includes a road trip to Grand Tetons NP and Glacier NP from Minneapolis. Ride quality is great both on and off road. I got a 2 inch lift in front and 2 inch lift in back. Before and after photos below....
Just a few more recent shots...
285/70r17 w/ 2” dobinsons lift and Slee step sliders...
Upgraded the stock suspension/spacer up front to a full extended travel Icon kit with resi’s and billet UCA’s w/the Delta Joints (buttery smooth, definitely maintained that Lexus “comfort” ride on the street). I still kept the airbags w/1.5 in. spacers in the rear (+ airbag trick, spacers keep bags at stock pressure) and some Icon 2.5 non-resi’s -planning to go w/the Aussie AirbagMan kit eventually and some 35’s as soon as my 33’s are dead. Next mod will be sliders cerakoted white to match and probably some TRD beadlocks in bronze because I think the stock wheel backspacing will be a problem with bigger tires. Wanting to keep the stock look but I may eventually do some color matched bumpers too. I do have a full size, deflated spare in the stock location.
Upgraded the stock suspension/spacer up front to a full extended travel Icon kit with resi’s and billet UCA’s w/the Delta Joints (buttery smooth, definitely maintained that Lexus “comfort” ride on the street). I still kept the airbags w/1.5 in. spacers in the rear (+ airbag trick, spacers keep bags at stock pressure) and some Icon 2.5 non-resi’s -planning to go w/the Aussie AirbagMan kit eventually and some 35’s as soon as my 33’s are dead. Next mod will be sliders cerakoted white to match and probably some TRD beadlocks in bronze because I think the stock wheel backspacing will be a problem with bigger tires. Wanting to keep the stock look but I may eventually do some color matched bumpers too. I do have a full size, deflated spare in the stock location.View attachment 2550652View attachment 2550651View attachment 2550648
That looks so good! Any details on the spacers?
I bought them from a mud member, they were a bit hard to find here but apparently they are pretty common to come by in AUS. The specs for the spacers were posted by the person I bought them from in a thread awhile back if u have a way to get them made...
265-70-17
Good Year Wrangler Ultraterrain AT
1.25" spacers
Stock 17" wheels
2" front lift 2.5" rear
Thoughts - at stock height a lot of cutting and modifying in order to get these tires to not rub. Took care of all of that and then lifted so did things backwards.
Would like a larger tire but just don't see anyway to mount a larger and wider tire without getting into the body mount issue.
Question - what is the largest recommended lift with stock components (without airbags)?
I don't know if I missed but looked through all the pages and didn't find any wheels that I short listed. Would appreciate if someone can chime in and let me know if they fit.
2004 GX
Suspension: Bilsteins 4600 (Takeoffs from a 2020 tacoma Trd Off Road).
Tires: Would like 285/70 C rated
Option 1:
SCS SR-8 17X8.5
Offset: -10mm
Backspace: 4.3
Hub Dia: 106.1
Weight: 23lb 13oz
Option 2:
Icon Rebound 17X8.5
Offset: 0mm
Backspace: 4.75
Hub Dia: 106.1
Weight: 30lb
SCS wheels weigh quite a bit less but are about $400 more than Icon's.
Wheels: Vors VE37 17x8.5 -0 offset
Tires: Kenda Klever RT 285/70R17
Spacers: None
Lift: Dobinson IMS59-50220 struts w/
C59-352 coils set to 3” in the front.
Dobinson IMS59-50701 shocks w/
C59-327 coils rear.
Other Mods:
-Dobinson UCA’s.
-Air ride delete.
-Metal tech coil conversion with eBay FJ spring isolators.
-Running board delete.
-RRW v3 bolt on sliders.
-EIMKeith PCK bracket.
-Front sway bar relocation bracket.
-Fender liner trimmed both sides on front inner, near radiator.
-Slight rubbing on body mounts when at full lock and compressed need to chop! :)
Spacers: None
C59-327 coils rear.
Other Mods:
-Dobinson UCA’s.
-Air ride delete.
Looks great. What is the real world height of the Kendas? Considering those for my next set.
