Great write up's
stevebradford
In the shop
bc
Rear axles:
Identifying differential ratios.
TLC FAQ - 9.1 Axle Codes
How-to: rear axle rebuild
Full floater bearing adjustment...
How to install/setup arb locker.
ARB RD33 landcruiser
digitalferg: Toyota 80 Series Electric Locking Differentials Retrofit for an FJ60 Land Cruiser (or other 40, 50 or 60 or even 70 or 80 series)
Tech Article: How to put 60 series axles under a 40 or 55 series
Building a full float rear axle.
Full float axle infrequently asked questions
Can a semi floater be converted to a FF axle?
Toyota locking diff axle shaft mod 60, 70, 80 series in case of axle spline twistage.
How to pick tires without ruining drivability.
OEM TYRES & RIMS
Part numbers:
Brake line 5 inches longer than stock napa part number 38009
Drain plug Allen head with magnet 90341-18021
Drain plug gasket 12157-10010
Hubb studs 90116-08325
Cone washers 42323-60010
Differential carrier (third) to axle housing gasket 42181-60070
Full float Tripod socket part number for wheel bearing nut 09509-25011
Full float wheel bearing lock nut post 08/80 axles 42427-60021
Full float wheel bearing lock washer post 08/80 42428-60011
Full float Hub to spindle seal 40,60 series 43422-60040
Full float hub to axle shaft gasket 43422-60010
Full float early axle shaft seal part number pre 07/80 90311-38146
Raybestos 60 series wheel cylinder wc37690
Torque specs:
Wheel bearing lock nut 43ft-lb
Hub studs with cone washers 23ft-lb
Differential Carrier Nuts 34 ft-lbs
Front axle:
Toyota Front Axle Rebuild
Off-Road.Com - - AISIN hubs - Indentifying and rebuilding
Knuckle centering tool. (Apparently unavailable from Toyota)Steering knuckle centering tool instructions (FAQ)
Very happy with this hub stud kit.
Trail-Gear Super Metal Hub Stud Kit, for 2 Hubs (300578-1-KIT)
Part numbers:
60 Brake caliper bolt 90101-12060
60 brake anti rattle clip 90468-12003
60 brake rotors 43512-60100
60 Hub dust seal 90313-93011
60 Spindle 43401-60060
60 Spindle bushing 90999-70067
60 Spindle gasket 43436-60011
60 Knuckle to spindle gasket 43435-60011
60 Knuckle cone washer 42323-60020
60 Knuckle stud nut 94115-71200
60 Knuckle stud washer 90201-12019
60 Knuckle stud 90126-12005
60 Knuckle seal kit 43204-60020
60 Knuckle grease plug 90345-53020
60 Knuckle felt seal bolt 91651-40612
60 Knuckle shim 0.1 43236-60010
60 Knuckle shim 0.2 43233-60011
60 Knuckle shim 0.3 43236-60030
60 Knuckle shim 0.5 43234-60011
60 Knuckle shim 1.0 43235-60010
60 Trunnion bearing 90363-17001-77
60 Knuckle bottom bearing cap 43232-35010
60 birfield outer snap ring 90520-27091
60 birfield Inner snap ring 90520-28036
60 birfield outer axle shaft 43405-60016
60 Inner axle shaft seal 90311-33085
60 Inner axle shaft right 43411-60060
60 Inner axle shaft left 43412-35010
60 Hub studs 90116-08325
60 Hub Cone washers 42323-60010
Wheel bearing star lock washer 90215-42025
Knuckle centering tool 09634-60014
Wheel studs 90942-02053
Wheel studs napa part number 6413126
Torque specs:
Spindle mounting bolts 34ft-lb
Knuckle studs 71ft-lb top and bottom
Locking hub cover bolts 7ft-lb
Brake caliper bolts 65ft-lb
Differential Carrier Nuts – 34 ft-lbs
Its good, but why???? the electric motor outside the housing exposed to the elements is a terrible idea...
Spend the money and get a ARB or even better call Cruiser Brothers and get the electro magnetic locker with two tiny wires and almost not moving ports or orings and air lines to contend with...
Cable lockers were the best idea toyota came up with, they are a course spline that are weak and support for those old lockers is not good.
Also to mention, I think the toyota elocker needs a FF axle to install in the rear simular to the Harrop locker that requires a rear FF axle. Also you need longer splines on the lone side I believe.. Lots of factors and cost go into both...
E-lockers are fine in the 1990+ Cruisers, but I agree with Diesel Cruiserman that an ARB or other after market is probably the best option for the older cruisers. Cost is about the same for a new ARB vs. old e-locker, and it is less work to install.
That said, the e-lockers in my experience are totally reliable as long as water doesn't get in them. Mine came with a rear, and i'm on the hunt for a front e-locker from an 80 series to put into my 70 series (they fit with little effort - both 8" diff high pinion setup).
Suspension:
Leaf spring measurements.
Leaf spring bushing sizes.
Part numbers.
Sway bar axle bushing 48815-10090
Torque specs:
60 series leaf spring hanger bolts 67ft-lb
60 series axle U bolts 90ft-lb
I do not have or do not sell the Harrop locker but if you follow the info you will see how superior they are to most, two small wires and holding power threw low voltage is impressive, no o rings to replace and less moving parts.
Drive shafts:
Identifying pinion flange bolt patterns.
Drive shaft angles.
60 series with h55 (5 speed)
img_1416-jpg.1557504
I would like to get better measurements of the length of five and four speed drive shafts.
Torque specs: 40, 60, 70. Series
Drive shaft flange - 54 ft-lbs
Transfer case:
Transfer cases ratios.
TLC FAQ - 8.1 Transmission & transfer Case Ratios (All :1)
Identifying your splitcase.
The Wagon Way
Splitcase
Vacuum to Manual t-case conversion
Another vacuum to manual
The Wagon Way
Split case gearing: lower low range stock gears.
For those upgrading to a h55 your split case must have this oiler cup provision.
For people adding a later 38mm case to a h55 this hole needs to me plugged.
Bolt differences between short h42 and the longer h42 and h55.
Want to extend/unplug your tansfer case breather. insert with tube 36419-60070
Part numbers:
Split case input shaft seal 90311-48012
Split case front output seal (early rear output seal) 90311-48022
Split case later double lipped better input shaft seal 90316-48003 (might not fit early split cases)
Split case 4 wheel drive selector shaft boot 36318-60020
Spilt case gasket between halves 33142-60030
Split case fifth gear oiler cup 33124-36010 Split Case Output shaft, without parking brake 36231-60021
Split case output shaft, with parking brake 36231-60031
Torque specs:
Split case output flange nuts 94ft-lbs
Motors:
Identifying what motor by vin.
TLC FAQ - 12.1 Production Code Listings
3b hard starts, two simple tests and one harder one.
1 - pull the buss bar and wire off the glow plugs. get a volt meter put it to the ohm setting put one lead on the block the other to each of the tops of the glow plugs. Make sure they all are near the same resistance to the block and none are open.
2 - before hooking the wire back up to the buss bar make sure it’s not touching anything put you meter to volts dc. Put one lead to the block and one to the glow plug common wire. Make sure there is 12vdc for at least 20 seconds cold (on 24vdc system less time is needed)
3 - Assuming 1 and 2 check out ok. Your not going to like this but you need a compression test. You will need a compression gauge that will go up to 500psi. More than likely your compression is low and even lower cold.
Other possible issues.
You could have air getting into one of your injector lines as the motor cools down and the fuel contracts it can pull some air in. Only effects the first start and acts like it’s missing till the air bubble works it’s way threw.
The edic also adds extra fuel while cranking to help with starting. The connecting rod can vibrate out of adjustment. While cranking check to make sure the swing arm on the injection pump is pulled back by the connecting rod towards the firewall. Once started it should sit loosely in the middle of its swing.
Slow cranking from weak batteries or bad connections will crank and start the motor but not give it that quick compression that will help cold diesel explode.
DIESEL SMOKE COLOUR
Basically there are 3 types of smoke emitted from a diesel engine: black, blue and white.
Black smoke:
Black smoke is the most common emitted from diesel engines and indicates incomplete combustion of the fuel. Black smoke causes can vary widely and include ..
· Incorrect fuel injection timing
· Dirty or worn fuel injectors
· Over fuelling
· Faulty turbocharger, or turbo lag
· Faulty or dirty exhaust gas recycling (EGR) system
· Incorrect valve clearance
· Incorrect fuel to air ratio
· Dirty or restricted air cleaner systems
· Over loading the engine
· Poor fuel quality
· Cool operating temperatures
· High altitude operation
· Excessive carbon build-up in combustion and exhaust spaces
Black smoke can occur across the entire operating range, but is usually worst under full power, or during the lag before the turbocharger boosts air supply to match the fuel usage such as in the early stages of acceleration and during gear changes. Moderate turbo lag smoke is acceptable; otherwise black smoke should be hardly visible in a correctly running engine.
Blue smoke:
Blue smoke is caused by engine lubricating oil burning. The oil can enter the combustion chamber from several sources including:
· Worn valve guides, or seals
· Cylinder &/or piston ring wear
· Cylinder glaze
· Piston ring sticking
· Incorrect grade of oil .. too thin and getting past rings, or valves guides
· Fuel dilution of the oil, making it too thin.
Blue smoke is often evident at cold start, which can reflect reduced oil control due to carbon fouling deposits around the piston rings and/or cylinder glaze. Blue smoke should not be evident at any stage.
An engine may burn oil without the evidence of blue smoke, because good compression burns oil quite cleanly, however, it is not acceptable for any new engine, or engine in good internal condition to burn large amounts of lubricating oil.
White smoke:
White smoke is caused by raw, un-burnt fuel passing into the exhaust stream. Common causes include:
· Defective fuel injectors
· Low cylinder compression
Low cylinder compression may be caused by leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze. When white smoke occurs at cold start and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing.
Continuous evidence of white smoke indicates a mechanical defect, or incorrect fuel timing.
Bj42 frame measurements. For fj40 diesel swaps.
d99d3a97-7ac3-462c-a098-7ef0bccc1e69-jpeg.1579788
Use in place of oil pan gasket.
18f2576f-e5b5-4ce9-ae17-862b2705bc31-jpeg.1584396
Part numbers:
3b oil pan drain plug 90341-12012
3b oil pan drain plug gasket 90430-12031
3b rockers 13812-56030
3b exhaust manifold gasket good steel turbo one 17173-58010
3b Vacuum pump oil inlet hose 90923-02072
3b Vacuum pump oil outlet hose 90923-02068
3b vacuum pump large banjo washer 90201-14099
3b vacuum pump small banjo washer 90430-10035
3b head gasket 11115-58110
3B/13BT Intake manifold gasket 17172-56022, which crosses to 17171-56010
3B/13BT Exhaust manifold gasket 17173-58010
3b front main seal timing cover 90311-50013
3b motor mount 12361-5803
3b air conditioning crank pulley 88451-25020
40 60 70 80 series air filter washable 17801-61030
40 60 70 80 series paper air filter 17801-68030
Fuel system:
Bleeding the 3b injection pump.
To bleed the air out of the injection system Crack the bleeder screw (circled in yellow) then untwist the pump (circled in red) till it springs up and pump till no more air comes out. Push the pump down and twist closed before closing the bleeder screw. Try that if it's still having problems you are going to have to crack the injector line top nuts all four (circled in green). crank the motor till diesel spills out of all of them, shouldent take long.
On The 3b there is a often over looked hidden screen in the banjo bolt on the primer pump where fuel line coming from the tank connects.
73132cf3-b633-45e2-afef-873d0d2fa0c8-jpeg.1580114
Part numbers:
60 series Fuel float sender 83320-69015
60 series float sender gasket 83361-20030
Electrical/Wiring diagrams:
Starter rebuild walk through.
Here are the Toyota part #s for a starter rebuild.
Heater fan/blower rebuild.
Blower Repairs
Coolerman's collections
Coolerman's Electrical Schematic and FSM File Retrieval
What glow plugs to use.
Which plugs should I be running - B, 2B, 3B, H and 2H diesels
Edic plug wiring.
Alternator plug wiring.
60 series spiking fuel and temp gauge.
Temp Sending Unit?
Part numbers 3b.
Alt Brushes 12v 021630-0530 Denso
Alt 12v internal voltage regulator 27700-38100
Alt 12v internal voltage regulator remanufactured 27700-38100-84
70 series internal voltage regulator 27700-57080 (might fit 40 series with exception to the plug)
Starter contacts at lordco: Wilson 45-29-6522 less than $10
Plunger: Wilson 45-29-6452 $12
Internal IC Regulator: Wilson 62-29-16029
Glow Plug Numbers
Manual 12V
10.5V for a 12V Cruiser
1980/10 – 1981/10 Cdn Spec BJ60
Toyota=19850-68010 12V-10.5V
Nippon Denso=067100-1330
NGK 7493 (Y-147T old number)
Bosch 0250 202 058
8.5V plugs for a 12V Cruiser
Toyota 19850-68030 12V-8.5V
NGK Y-128T
ND 067100-1350
APS 5013
EIKO GT208
JKT PT104
MAY PT104
Manual 24V
1980/08 – 1981/10 BJ42
1978/03 – 1980/06 BJ40
Toyota=19850-68040 24V-20.3V
Nippon Denso=067100-1161
NGK 3030 (Y-178T old number)
Bosch ???
Superglow 12V
1981/10 – 1985/10 BJ60
1984/11 – 1986/08 BJ70
Toyota=19850-68050 (51) 12V-6V
Nippon Denso=067100-1680
NGK ???
Bosch GPT-214
HKT PT-146 QGS type
Champion CH-125
Superglow 24V
1986/08 --> BJ70
1985/10 --> HJ60
1981/10 – 1984/10 BJ42
Toyota=19850-68060 24V-14V
Nippon Denso=067100-1460
NGK 2188 (Y-197R old number)
Bosch 0250 202 076
Steering:
40 series steering linkage stock measurements. Would like to get the same for the 60 series
Sloppy 60 series steering column ujoints?
This one from napa comes with a grease zerk.
Also have been told those Toyota u joints are the same from early Toyota Corollas drive shafts hah!
Torque specs: 40,60,70. series
Tie rod/drag link clamps 27ft-lbs
Doors:
60 series window felt options
70 series inner door window felts
Part numbers.
Retainer clip for cylinder door locks 69681-89102
40 series Cylinder lock set 69005-90316
40 series Ft Door Weather strip RHS 67861-90300
40 series Ft Door Weather strip LHS 67862-90300
40 series Run (Window Channel) 1/75-9/83 W/O Wing Window (2 needed) 69105-90300
40 series Weather strip Outer Window Felt 1/75-5/80 (2 needed) 68180-90300
40 series Weather strip Inner Window Felt 1/75-9/83 W/O Wind Wing Window (2 needed) 68160-90300
40 series Front Door Window Cushions (4 needed) 67434-90300
40 series Weather strip Ambulance Door Glass RHS/LHS (2 needed) 68291-60030
40 series Ambulance Door RHS Weather strip 68292-90301
40 series Ambulance Door LHS weather strip 68291-90301
Brakes.
Part numbers 60 series.
Master Cylinder Raybestos Lordco #MC39996
Brake Caliper - 65 ft-lbs
