I have my rear drive shaft out becouse I worked on the transfer case. I want to clean and lube it properly. First of all any grease recommendations? Should I just use a good high pressure grease? I know the u joints just fill until clean stuff flows out. Any rexomendations on the slip joint? How do I clean it out and how much fresh would I put in with out hydrolocking it? Do I just slide the two half's apart and wipe out what I can? Lube up the shaft by hand and slide back together? I think it was pretty full of old grease. I had to remove the zerk and to compres the shaft enough to get it off. Squirted out a good bit of old grease.
Edit. Just read a long thread about which grease to use. I am not going to over think the grease for the u joints. Just going to use some good quality grease and keep it fresh! But still. If you guys know about the slip joint cleaning please fill me in.
