Man I love the look of this truck. Those are the wheels I hope to come up on someday, but in the mean time I'll keep beating my 16's. What did you do for a spare? Or do you not have a full size?
It was a Pioneer Premier AVIC-F90BT I had leftover from a old car. Added the iphone interface and a rear view camera.
My Highbeams burned out, so I put a set of high quality aftermarket hid's in place of the factory lights, these have to be twice as bright!
Just ordered HID's for the low beams and fogs as well, and still need to get around to painting the bumpers and lowers. Slow progress for now as I am working 70 hours a week lately.![]()
I thought those were the daytime running lights?
What HIDs did you opt for?
I'm shocked they said engine blown. Did your mechanic say if the 1 and 8 was a VVT engine?="GDenver ****
Unfortunately the car had a timing belt failure on I-225 after only 40k, and I had to deal with that ordeal. Had the car towed to Slee in golden where they told me I should sell the car for parts ***. ***** Now the Toyota literature and the common impression is that this is an interference motor, but guess what, it's Not!!!!!!!!!!! I was lucky enough to talk to a mechanic who had fixed many of these motors both in the LC and TUNDRA, and he said out of 8 TB failures, only 1 had damage to the head. If the timing belt fails on you, or in my case a bearing, you can check the condition your motor by putting a rachet on the cams and spinning them manually. If there is damage you will feel it! After we verified that there was no head damage, we put it back**!!!****.
I opted for DDM tuning hids, they have already had to replace them once under warranty. Just ordered new LED headlights, to replace the HID's. Those are the drl's and the high beams, if you switch to hids you loose the drl's, but that's what I wanted. All lx470s in 99 were equipped with the 80% lockup LSD as far as I know.
Checkout hidplanet.com for all you ever wanted to know about headlights, lamps, housings and retrofitting. If you search "LX470" there's a good thread by TRSNick (mud member) that links back to mud and shows how nicely LX projectors can be HID retrofitted.Man I have a lot to learn... LEDs are preferable to HID, yes? Less power consumption, lower heat? Not sure what DDM is. Feeling lame...
