Scott68FJ40
I hadn't driven a cruiser in about a year so I took one of his for a few laps around his place.
I'm pretty sure that the front spring pack was intended to have an extra leaf over the rear to support the weight of the F/2F. I'm sure you could find it somewhere on MUD with some searching.
I'm not a SBC or a Saginaw guy, but I really enjoy finding this thread with new posts in it. Hope you are getting close to finished so you don't miss too much of the wheeling season!
If it were me with what you have already, I would put the Saginaw back in. You've been running it forever and other folks run them forever, I would maybe adjust its location relative to the cross member and/or reinforce the hole in the crossmember and call it good for another 17 years or however long you've had it.
Miss wheelin' season? Spoken like a true Mile High Man.Wheelin' season is over dude. At least it is if you're running an open top FJ40. The furnace is coming on over here. I grew up in Denver and surely miss the summers there.
I'll be lucky to get this thing rolling again before the next season ends.
Thanks for the input, but I'm confused by what you mean by the extra leaf over the rear?
And after scanning your FJ60 PS install, I would think you would be more of a fan of me going the Scout route possibly. Any regrets with that?
Figured that, depending on whereabouts in AZ you lived, maybe the weather would be a little more temperate.
I meant that I think the front leaf pack has one more leaf in it than the rear leaf pack has, at least from the factory. I think the front pack has 9 leaves, the rear has 8 leaves, or something like that. I'm probably wrong though.
...... I'm not really sure how it's going to do when put to the test. And I'm not sure if a Scout box can handle higher loads than an FJ60 box; the 3 bolt configuration always weirded me out a little bit. But from my reading here on MUD a Saginaw will provide more boost with larger tires than the others will; and so I figure if you haven't had any problems with it in the past why change? It would be a bummer for you to go to all the work of changing the steering box configuration around only to find out you're not happy with how it performs as compared to your old setup.
