Just about done, stabbed the distributor today and finished replacing almost all the hoses I could find, both OEM and aftermarket. Also replaced all the belts, reinstalled the shroud and fan (that sucked), and chased down coolant leaks as they came up.
I didn't get a ton of photos, but here was one that I thought would be good tech down the road. I was able to find Gates parts numbers for just about every formed hose on the rig, but the one that wasn't super clear was how to replace the formed hoses for the rear heater closest to the passenger frame rail. Gates 19038 provides both the bent parts and a straight run for the short rear vertical heater hose piece coming off the U-shaped metal hose, near the firewall and close to the passenger wheel well.
Some photos. My hoses were original and very, very spongy and soft:
These worked great, but I tried using some of the OEM clamps that were a size too big and they definitely leaked, ended up replacing them with the old worm band clamps and getting the ol' coolant bath under the rig while trying to replace them.
Everything else is buttoned up. Haven't fired it up yet, ran out of daylight but it's all ready to go with coolant. Will let it sit overnight to make sure there aren't any more leaks.
