As said above, the end pieces just unscrewed. If I had it apart, I would show you more... But there is REALLY nothing to see...
Shawn
Shawn
The Napa Part # 819-5565 refers to the Manufactures Part # 5200-50.
I Googled this part number and found several distributers. I just installed item number 5200-50. RV Gas Strut I had a pair of them delivered for under $37, which is what Napa wants for each spring.
The tube end is 15mm dia. which fit perfectly into the upper portion of the old chrome tube after I removed the plastic end connector. After fitting the gas spring into the old tube, I cut the other plastic connector to length so that it was exactly the length of the fully expanded tube.
Works like a champ. Now I just stand back and watch as my rear gate is lifted to its max height.
Not sure if this is what you are looking for...
Shawn
What is that "Bubble" in your rig...?
I ordered a pair of 5200-50 gas struts and received them today.
This sounded like a one banana job, but I quickly ran into complications.
When installing them per the above instructions, they jammed with the lift gate about five inches short of closing. Measuring the struts, they needed to close another 3/4".
It's possible to hacksaw off the thread on the tube end (thick end) of the gas strut. I also cut the plastic coupler on the rod end to the same length as the threads. This will allow it to seat deeper in the old spring strut assembly and fully collapse.
The problem with that is the gate does not fully come up. If you are six foot or taller, you'll not like this at all. This is because the gas strut is now recessed inside the old spring strut assembly.
The only way to both lengthen the travel and take up the excess space that I could think of at the spur of the moment was to cut a few coils off the old springs and try them. By trial and error I found a length that works reasonably well, but the coils bind just as the assembly closes. Works, but not ideal. Also note that I have a 1971, which appears to be the same model year the above instructions were written for.
It's definitely an improvement over the old setup, which was a royal pain to try to set the tension right, plus tighten and loosen the locking collar, which was worn out. But because of the issues I ran into I'm hesitant to recommend it. At some point I'll probably use a naked set of gas struts and get rid of the old spring tubes entirely. But for now this works.
I just did this mod using the http://www.adventurerv.net/gas-spring-60lb-ext-comp-wplastic-ends-p-2605.html and I have to tell you it was easy and works like a charm.I did this mod today and am very happy with it. I ordered the old NAPA part#819-5565 struts about a year ago, of course they didn't fit, so I tried again by ordering from Adventure RV Gas Spring 50Lb 17 Ext 10.25 Comp W/Plastic Ends - $10.49 I ordered the 5200-50 for $31 shipped and was actually sent the 60lb struts. I decided to use them anyway and did the same as mentioned previously by unscrewing one plastic connector, trimming its mounting screw off, and then cutting roughly half of the other plastic connector off so that it is flush with the threads of the old tube when the strut is placed inside. I then reassembled everything with the struts inside the old tubes and DID NOT have any problems with them jamming short of closing or the hatch not extending fully. The hatch is roughly parallel to the ground at full extension and I can press it up less than .5" further before the hatch reaches the end of its range of motion. I'm also happy w/ the 60lb versions as they aren't hard to close, seem like they would be stout enough to hold the hatch open while driving (dog in the back, lumber etc..), and get the hatch open in a hurry. Thanks to those that came up with the idea.![]()
