I can definitely fit the reservoir, pump, and fuel cooler here in the engine bay, and it's conveniently right next to the battery and the last section of return fuel hose that wraps around back of the engine before it connects to the hard line, which is a good tie-in point. Then I would then route coolant lines up front to a small radiator that I already confirmed will fit behind the grill, giving it the coolest air possible.
Unfortunately, it means if I want onboard air at some point, then it can't go here. But that's okay.
