FZJ79 Stock Gearing (8 Viewers)
good question mate
as a nutted my front diff yesterday and need a new one
i would love to know the ratio of the petrol 79 series as the wreckers will only have diesel diff nuggets and i think there a different ratio:hhmm:
i tried to found out what ratio my code say it would be but couldnt
if i post my axel code maybe someone can translate it:hhmm:
OK,lets have a go
I think it would be the same as the HDJ78/79
just had a look under my bonnet
my trans/axel code is h150f (gearbox) AO2B (diffratio)??
how to get A02B and change it to a ratio lol
i can use a 105 series petrol front diff ay but auto or manual?
A02B - 4.083 ratio ??
Read the Axle Code from the vehicle indentification plate.
first digit: ring gear diameter
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
- no ring gear = FWD
Second, third digits: gear ratio
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.909
32 6.591 or 4.807
33 7.503 or 5.583
34 6.781 or 4.786
35 7.636 or 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Fourth digit: no of pinions, ltd slip-yes/no
Code pinions ls
2 2 no
3 2 yes
4 4 no
5 4 yes
Sorry the pic aint the best of quality but is says
on the second line trans/axel h150f AO2B
did they make a 4.083 or is something missing:hhmm:
Thanks for the help fellas
but still a little unsure are the code works out to be 4.1 but the websites rosco supplied with the goodies says fzj79 has 4.3s...which leaves me still unsure
Landcruiser Front Diff Crown Wheel & Pinion 43/10 - eBay, Other, Car Parts, Accessories, Cars, Bikes, Boats. (end time 28-Mar-10 17:42:31 AEDST)
all models bar TD damit
i wanted to have a diff ready to put in when i pull the blown one out
im thinking ill put the front diff out then i can count the teeth and go from there
If you havea look here it shows the 4.3 ratio as the only diff available for the 79 series,at least in the ARL spec models.
Do you have K285 on your plate anywhere,thats the code for a LSD 4.3?
http://www.toyodiy.com/parts/p_G_2000_TOYOTA_LAND+CRUISER_FZJ79R-TJMRKQ3_4101.10.html
to be safe, pull the diff and do the count.
unless you are loaded then you can buy both and use the one you need and return the other...personally, i thought all 79 series were 4.30 but that code doesn't work out to it.
thanks fellas for the imput
ill wait and pull the diff out next weekend or so ,and work it out then we can all learn a bit of fzj79 ratio :D
(lucky i got hubs on the front and part time 4x4 so i can drive to work and stuff 2 ) the fun bit was trying to get out of the place i blew the front diff in 2WD a boggy sandy river then all the boggy dry sand tracks when out of the river:doh:
doesn't look like it takes too long for the sand to settle back in place. the sand also looks deep on that one front tire...
Moore river claims another victim?
Yep normal 4x4 cruisein driving on the surface is no worrys its once you click it in 2x4 and start to act 17 again and break through the surface that inch or two then it becomes a challenge but all in good fun
4.3
I have 4.88 in stock too.
Thanks mate i pm'd you
yep sure did mate but a good change of weelin from pipadini etc and pines
