8/1977 FJ40 cali spec fully smogged rig with charcoal canister, egr, ABV etc. (see avatar pic). As original as they come,freshened up a couple years ago.
new OEM gas tank,
new see through filter,
reflective tape wrapped hardlines,
rebuilt carb.
new rubber lines from tank to pump (i dont thing there is crap in the lines or the carb
I have no issues with the truck on my 8-15 minute commute.
I took the truck 440 miles this weekend to the coast. Yee haw, my furthest trip. 90 degress outside and a headwind of 15 MPH. i cruised at 60 where is seemed comfortable (33 in tires)
100 miles in, the truck falls on its face. I stop at a light and I shift through first, second, third fine. But on the transition to 4th back into the cruising speed, she falls flat sputtering bucking, kicking, etc. -fuel starvation. I have an empty bowl after immediate shut off and coast, half-full bowl after a moment of idle in the sight glass.
I changed fuel filter, no help
there is no whoosh out of tank when opened,
I cracked the gas cap for vent, no help.
I carried a spare gas can and i decide to fill the fuel tank to the brim. (6 gals the first time) Immediately, all symptoms resolve and she runs like a top......For 3 gallons and it does the same exact thing every 3 gallons of fuel used (45 miles or so). When the tank is filled to the brim, its a galloping jessie. After 3 gallons are used, its nonfunctional from starvation.
To me, it seems there is a vapor locked type scenario where the pump is not able to pull enough fuel out of a less than full tank. When there is a full pressure head, it works great. But when the fuel dips below full, it cant go above 30 mph.
So.....my question.
why can i run fine with a full fuel tank , but when the top of the tank is used, its starving every 45 miles?
thanks for the help
hOOter
new OEM gas tank,
rebuilt carb.
So.....my question.
thanks for the help
hOOter
