For the past two years, since I swapped to an LS3, I've been working through a persistent fuel tank cavitation issue.
Problem: After >1h of driving, exacerbated when going to elevation (11,000+), the in-tank fuel pump starts to whine, building to a wailing banshee scream. This began since the swap and persists through a tremendous amount of work and expense including swapping fuel pumps four times, a custom Chevy evap/recirc installation, a rerouting of fuel supply lines away from heat sources, using vented and non-vented gas caps, pulling the entire system and rebuilding it, and more. When using a vented gas cap, pressure builds such that fuel will pour out of the gas cap even when only 1/2 full. I've tried non-ethanol fuel to decrease pressure with no change in behavior.
Additionally, my father-in-laws truck was swapped at the same time, side-by-side. He has a vented gas cap and very basic evap setup and has no problems. Something is obviously wrong I'm looking for ideas on what to do to resolve this issue. At this point nothing is off the table so take your best shot.
