- Thread starter
- #21
Update:
Fuel pump was replaced as the potential culprit. Thinking was, with the closed, non-vented system in place for months, the fuel pump was damaged. The evap/recirc system is in full working order (tested and validated), with the recirc pulling fumes appropriately and the venting working as designed.
After forty-five minutes of driving in the mid-day heat, the fuel pump began it's all-too-familiar ramp to Wailing Banshee loud. No change in the issue.
I'm now absolutely convinced it's temperature related. Something is cooking the fuel tank. I confirmed as much by taking readings all around the fuel tank, with it hitting 185 degrees at its closest point to the exhaust. Additionally, the evap hose routes very close to the exhaust and was 162 degrees at its warmest reading.
Next steps:
- Wrap the muffler with a kit from Design Engineering
- Wrap the 4" exhaust pipe coming into the muffler, back past the cross-member (approx 8-10" of muffler pipe)
- Wrap the evap hose that runs close to heat sources
- Replace the Walbro fuel pump with a Quantum unit which is quieter and more efficient
We are not going to touch the fuel supply line as it didn't get more than 128 degrees (at the elbows) and was around 115 at the filter/regulator.
Next steps:
