FWIW, most of the tools I've seen suggested above have been items I've been able to rent at either AutoZone or Advance Auto if you want to try before you buy
I broke a questionable TRE - had the enclosure separate from the ball. Looked like a little trailer hitch on my steering arm. But the joint was suspectI never broke a tie rod or ball joint with a pickle fork. 0 out of 500. If you want to save the rubber boot for reuse, you have to pull it down and squeeze it in between the tines of the fork. Stop with the forking hate.
Gotta have the tools!
I'm 280lb, and a tradie who knows how to swing a hammer, if a 4lb hammer on the pickle fork wasn't enough, then seriously, it's the wrong tool.
Pittman arm puller has always worked easy
Oh yea? I bet you didn’t fork it from both sides. I have broken the silly OTC removers, so I don’t waste my money on them anymore.
2nd vote for vibration. Hit it 90 degrees from the stud axis with a lighter hammer. It's the acoustic wave, not brute force.Vibration is also your friend, tension the puller, smack it with a hammer, repeat, until it pops.
GAWD! Looks just like the fork I had, but I couldn't figure out what to do with it!Gotta have the tools!
I think the idea of the two-hammers method is that each hammer blow sort of acts in opposition to both free the stuck object but cancel each other out to not transfer too much energy to what the stuck object was fixed to. Does that make sense?
