Front End Drops Overnight, AHC Reservoir Rises (Even Drop Both Sides) (1 Viewer)
Costa Mesa, CA
Hey all,
Looking for some insight. My 2000 LX470 is dropping the front end evenly and slowly after shutting the engine off. It takes about 30 to 45 minutes for the front to fully settle, slow enough that I can't actually see it moving. The rear stays steady the entire time.
As the front drops, the AHC fluid level in the reservoir increases. That tells me the fluid is not leaking externally. I also do not see any signs of external leaks. It seems to be flowing back into the tank. This has been happening for about a month, but the AHC fluid level has remained steady. I have not had to add more fluid.
I washed the road grime off the front struts. Both struts now look dry after sitting overnight, with no visible signs of leaking. When I start the truck, it raises back up without any trouble and rides normally. It also levels correctly while driving with no unusual behavior.
When I bought it, the front end struggled to lift. I fixed that by adjusting the torsion bars while watching the pressure in Techstream. Since then, everything has worked well while driving, but the front still settles after shutdown.
It is also intermittent. Sometimes it can sit a full 24 hours without dropping. Other times it will drop within an hour.
There are no current codes on the AHC ECU. There was an overpressure code when I first got it, but that cleared after I brought the front torsion bars into spec. The rear is still slightly over spec (less than 1.0 over, although I do not remember the exact value).
From what I have read, this could be caused by one of the following:
  • Internal leakage in the front valve block allowing fluid to return to the reservoir
  • Worn front struts, although I would expect uneven sag, poor ride quality, or visible leaking if that were the case
  • Some other factor I am not aware of
Things I think I have ruled out:
  • Leaking - fluid remains steady
  • Sensors - Correct me if I'm wrong, but this is ruled out by the truck being off when the issue happens
Has anyone seen this exact issue? If so, did replacing or rebuilding the front valve block solve it? Is there any way to confirm the valve block is the issue before replacing it?
Thanks in advance!
Standard tax:
I think you're on track with the internal leaking. Though I have almost no experience with AHC... interested to hear what you find.
I would bet the valve assembly is allowing fluid to pass. When it pressures up to raise the suspension, these valves should close to keep the pressure/fluid in place. I’ve been eyeing this repair and part to avoid being caught with the part no longer available. I don’t have an issue just yet, but I’m certain this will eventually be a problem. We can’t expect those valves to seat and seal 100% after 20 years of use. Note that this is just a suspicion, not definitive. Here’s the part:
TOYOTA LEXUS Genuine Valve ASSY Height Control No.1 48940-60010
Sounds like the valve, but that's a pretty rare failure.
I'd start with a fluid flush. Perhaps you've got debris in the fluid and it occasionally prevents the seals in the valve from sealing properly.
If that doesn't do the trick, I'd do the valve.
Thank you all for your help! I ordered fluid and did a fluid flush per the process in another thread, and it seemed to help some. The old fluid definitely had some fine particles in it and was brown instead of the nice red color of the new fluid. The problem frequency went down (no dropping for 48 hours). I thought I had the issue fixed, but today I saw that it had dropped about 2 inches while we were in the store for an hour.
I'm going to wait another couple days and watch it, but I'm probably heading towards the valve replacement. The fluid flush was badly needed either way.
I did notice that the cylinder- shaped accumulator had only maybe a thimble-full of fluid drain. What does this part do? I understand the function of the main pump, valves, globes, and actuators, but I don't know what this cylinder does (drivers side frame rail between the two globes).
Question - does anyone know of documentation on replacing the control valve? With this being my daily I want to be as prepped as possible to help it go smoothly. Or at least see if I'm getting in over my head and I would be better off at a shop. It seems this replacement is pretty rare from my searching.
If you hadn't already seen it, you want the repair manual. It should be in the Resources section of this site. For the 2005 Lexus LX470 manual, page SA-153 has the "control valve assembly." Download the repair manual pdf, open it up, ctrl-f (find/search), type in that keyword and you'll get plenty of results.
There are several diagnostics pages on AHC. There's a page on special suspension tools that you might want (SST). I'd include screenshots, but I'm currently on my phone... plus you'll learn a lot by searching through the manual pdf for this.
Edit:
2000 LX470 FSM, 2301 pages
Thank you, very useful! I hadn't seen the manual. It confirms the valve assembly as the most likely issue and shows the removal, which doesn't look too bad. I'm glad to see it's just a standard bleed process afterwards.
I replaced the control valve a couple days ago. Since then, the front end has stayed up. Looks like it's fixed!
For anyone else that needs to do this repair, note the following:
- pick up a set of flare nut wrenches. You cannot remove the nuts with a combination wretch, I tried and it immediately stripped.
- get standard, wobble, and articulating extensions for the flare nuts wretch/ ratchet. Tough access made what should have been a 1 hour job turn into a 6 hour job. An inspection mirror would have been handy too. 4 of the 5 lines are above the box where you can't directly see them easily.
- bleed the fluid until you're on the bump stops before starting. If you don't, it will pour on you when you loosen the 4 output lines.
- I had a helper watch the reservoir because I didn't want to deal with priming the pump if it ran dry. It will continuously leak from the supply line unless you have a way to plug it. I did not. No big deal, we just topped the reservoir off as needed. Have extra fluid on hard.
Overall, it was not technically difficult but annoying due to the line placement. The service manual was accurate and helpful.
I actually uploaded the whole 2500 page service manual to chatgpt out of curiosity and it came to the same conclusion. It will be a nice tool in the future.
