i would like to see pics of welded ears ,ive never seen it done that way
You WILL need a proportioning valve. Just do it. Got mine from Summit and it was about $40.
Ed
bbalbano, I agree with the above. I got the parts to do this cheap from someone else on the board. I would recommend you go the Minitruck route. If you're still interested, I can take pics. The point I was making is that this method is better than the bracket.
The only option it has left me with is to have my coarse-spline birfs cryo'ed by a local place. Once those blow up, I'll be going Minitruck with Longs.
I would still like to see the pics.
Would you recommend the valve on the existing m/c, or should I definitly change the m/c and use the valve also?
poser im wanting to see the welded ears on the knuckle .
X2 on the pics
Im not considering doing it, I just want to see the pics... Im already set on the mini swap.
Thanks
Did you see this.........................https://forum.ih8mud.com/showthread.php?t=148818
It might make your swap a little simpler. Maybe no need for the SST to perfectly center the knuckle. See PinHead's post #8 in the link.
I would have used them, had they been available when I went through my front axle.
You've made the right decision.![]()
Ed![]()
