Nice. Looking forward to what you do with the rear bumper. I like your progress on the drawers also.
I got it done with an 1/4" air die grinder and a course cone tool. I think the dremel was just not enough HP. I was able too grind the frame without getting into the nut threads.A common problem from what I have read but the rear bolts holes are misaligned.
I tried to pry them before I put the bumper on but there must be some rust between the tab and the frame.
I tried opening the holes by grinding them with the dremel but had no luck they where too far off. I also drilled some pilot holes on the inside of the frame and tried to push the nuts into place - they didn't move.
So I don't have the extra wing supports on now. Looking at options. I will either cut a hole in the frame to fit a real nut & tool in OR put in a rivet nut.
Still need to wire the license plate light, relocate the backup cam, & figure out some additional back up lighting. Also may add some more turn signals for when I have the Alu-box installed.
