my motor has a 180 thermostat and the radiator keeps it there........
To keep this thread going: I just got my DC Control box yesterday (damn this thing is small) and am going to get as much set up as I can here before taking out my clutch fan and installing the Contour fan.
I'll be wiring the controller to a 40A NC relay that'll be controlled by a guarded switch on my dash. I'm using an NC relay so that it will only be "on" when I want the fan killed and won't have to be under a constant duty cycle.
I have yet to find out how much this will pull when it spins up. I guess I'll find out when I kick on my A/C to test it's spool-up to 50% and see if the 30A fuse pops or not...
You shouldn't have to run the power for a DCC controller through a relay to enable on demand shutdown of the fans. Just wire the 18 or 20 ga yellow input wire through your switch and the switch to >6 volt power source. This can be powered either by constant or ignition hot depending on whether or not you want the fans to shut down immediately when the ignition is turned off; mine is constant and the fans slowly turn off about 10-15 seconds after shutdown. If you open the switch (the yellow wire isn't seeing >6 volts) the controller will shut down.
Then run the 10 ga fan power to the battery with a fusible link (supplied in the kit).
Having just seen the DCC controller on the web site....how do you connect the fans...it looked to me that it just hase one connection point. DO you wire both fans to the same connection point on the DCC controller? I don't recall seeing any really good pictures or instructions on the web site about dual fans?
Good to hear from you Marco.. I've got my 5.7 vortec running and trying to prep for getting the A/C setup.
I have a spal controller which as I understand will control two fans with the addition of another relay setup. It can vary the speed of one fan 1 and can turn fan 2 off and on, as I recall.
Rright now I'm running about 203F or so in town and about 210F on the hwy. Truck will cool down to around 200F at extended idle. Aftermarket 4 core raidiator and one 16 inch SPAL fan with a "custom" shroud. THe fan is offset to the drivers side of the radiator to clear the water pump. I've debated on trying to install a couple of "flapper valves" in the shroud to allow better air flow on the hwy but I don't know anyplace that sells them. I have the A/C condensor installed but have not finished the setup for the GM/ Toyota hybrid A/C yet.
Can someone post their temps.... with ambient weather in the 80's or hotter. Don't know where the temps are going when the A/C starts to work... I assume they will increase.
Don't know if I can get better cooling than the setup I have now? See attached pics.
I was never able to find anything on the web. I suspect that some of the hot-rod fabrication shops either make these things in house or know of a source. I never came across any cood information. I've seen pictures, but so far I've not gotten beyond that. I think some of the OEM fan shrouds of various mfg have these things made into them.
Yes, you wire both fans to the single output stud on the controller. It runs both at 0-100% based on radiator temp. You also need the filtered surge protector (1.5 KS on the accessories page).
