For Sale @ High Desert Cruisers (23 Viewers)
No Affiliation!!!!
33x9.5 BFG All Terrains
Tall BFG All Terrain Tires - 15s
That didn't take long
Hello - I have a buddy looking for a T-Case for his FJ40 (4 speed transmission) Does anyone have one or know of one that is available?
Thanks
Thanks
Not sure about the timing but I'm replacing my 4 speed trans/t-case with a different drive train in the next few months (hopefully sooner) I rebuilt them ~2009 and probably have less then 5k miles on the rebuild.
I'm hoping to start once I empty the garage and could be done quickly for the right deal...
Thanks! I will mention it to him and see what his time frame is. I will be in touch.
'99 4Runner parting out, rolled.
Toyota 4runner
Parting out 1999 Toyota 4Runner or selling whole as is for an offer. The 4 runner was recently wrecked but back bench seat, running boards, front grill, rear bumper, lift gate, back window, motor (225,000 miles) rims and transmission are all still in good condition and other parts as well. The car starts up with no problems also shift with no problems. No smoke or leaks. Title is clear. before the accident it was regularly serviced and used as our daily driver. Call or text
The vast majority were V6s.
Thanks
I think we've got one that Dad would part with.
Not sure when the next time I will be in the shop is. Want a transmission to go with it?
Dan
Hey there!
I'm new to ABQ as well as the IH8Mud group. Anyone have a pair of stock rear coil springs out of a non-AHC 100 series laying around? I'd hate to pay new prices on something that most people take out when they lift.
I have retired and need to get my garage in order.
I have no use for the following and have attempted to price items to sell looking at sold prices on MUD when I could find them. So if you do not think that the posted price is justified, please let me know your justification for reducing price, or just make an offer.
Several items are listed as free with purchase of another item. Intent is to give one free item with purchase of another item of equal or greater value.
I do want this all gone.
I have photos of each item I can send to anyone interested, unless otherwise noted, and can take additional photos.
There will probably be more items listed later in a new thread.
I have given part numbers where possible and researched applications when I could, however you need to verify parts fit your application on your own.
1. 2F rear main seal #90311-99001 $30
2. 100 series LC drive shafts, removed at front 152k, rear 168k miles. Shop ticket number suggests they have been rebuilt. Removed when trying to eliminate drive line vibration. $75 each
3. 100 series LC front CV shafts. Removed when trying to eliminate drive line vibration. $40 each
4. 100 series LC headlamp upgrade. Higher wattage lamps modified to fit LC. 4 extra new in box lamps. $50
5. 1975-80 2F smog pump, valve, hoses
6. 1982 smog valve and hoses
7. 19100-60064, 1971-73 distributor
8. 19100-61021, 1976-78 distributor
9. 029100-61020, 1973-77 distributor
10. 31210-60070-84 clutch cover removed from 1987 FJ60 at 20k miles of use. Replaced when installing 5 speed tranny. I have documentation on the mileage. Machine marks still apparent. $75
11. 87249-90A01, 1981-87 rear heater inlet hose $5
12. 87249-7502085-87, FJ60 rear heater outlet hose $5
13. 88840-14010, AC “O” rings for FJ60, $2 or free if you buy another item
14. 90334-07009 head plug $2, Free if you buy another item
15. 90521-34003 snap rings $2, Free if you buy another item
16. Approx. 85’ of 4 pair data wire, makes good speaker wire. $2, Free if you buy another item
17. AT strainer for 1998-2003 LC $20
18. Carb, 1973-1974 $75
19. Carb 1977 $75
20. Carb 1981 $75
21. Cargo hold downs $5, not sure of application
22. EGR cooler, 1 of 3 units $50
23. EGR cooler, 2 of 3 units $50
24. EGR cooler, 3 of 3 units $50
25. Exhaust cushion and AC compressor gaskets $2, Free if you buy another item
26. FJ60 4X4 badge $2, Free if you buy another item
27. FJ60 Land Cruiser badge $2, Free if you buy another item
28. FJ60 interior door handle trim $2, Free if you buy another item
29. FJ60 interior light switch for door, includes door stop pin and random breaker $2, Free if you buy another item
30. FJ60 HAC valve $10
31. FJ60 heater fan $35
32. FJ60 ignition switch $20
33. FJ60 mud flaps $2, Free if you buy another item
34. FJ60 rear side vents $2, Free if you buy another item
35. FJ60 rear spring mounts and U bolts $15 for the pair
36. FJ60 rear window washer bladder and pump $25
37. FJ60 Smog BVSV $5
38. FJ60 SS gutter trim $15
39. FJ60 sun visor pair $20
40. FJ60 transfer shift lever boot $10
41. FJ60 tailgate one $50, some bondo and primer
42. FJ60 tailgate two $60, looks pristine
43. FJ60 windshield gasket and SS trim $20
44. FJ60 wiper screws $2, Free if you buy another item
45. Front license plate holders FJ40, 45, 55 $5 each
46. Hardface weld rod $5
47. Ignition resistor 1976-1978, new unused $10 #90919-04020
48. Igniter assembly for 1975-1977, untested $5 and return within 2 weeks for refund if it does not work.
49. Intake Snake for cleaning throttle body $20 Run-Rite.com : PRODUCTS: Intake Snake by Run-Rite
50. MAF sensor for 1998-2006 LC, 2003-+2005 4Runner. Ran for about 5k miles while trying to eliminate drive line vibration $50 #22204-75020
51. Manifold cool fan #16360-61015, fits 1981-80. $20
52. Non USA mirrors for *J60, excellent condition, $200 for the pair. May fit 62 series.
53. Smog air rails $20 each
54. Blue VSV $2 or free with another part purchased
55. Speedo cable thing, have no idea of application. $2, Free if you buy another item
56. LC tow hooks for 100 series $10
57. Utility lights. These were brake and back up lights for Terex mining trucks. Mount is ½” threaded stud. $15 for all 3.
58. JF60 factory wheels from 1987, I have 9 for sale at $50 each. No photo
59. BFG All Terrain, LT285/75R16, Load Range D, there are 5. Tread depths of 6/32, 9/32, 10/32, 6/32, 4/32. $60 for all five. No photo. Want to sell as set, so if you only want partial, you will need to get rid of the others yourself.
Do you still have #32 J60 ignition switch available? Thanks
  • Back
