bull said:If it makes any difference I went wheeling in my 100 series 3 times over 2 weeks with the N74Ls with only the spring retainer and no bumpstop installed and it worked fine..
Do you have any photos of a 100 series? Mail them to me and I can load them up on my server.
MAD FLEX![]()
EL_3grab said:ats4x4dotcom
How much they cost (blisten shocks) and what do you offer beside them for the LC100 ..
DBS311 said:Hey ATS4x4, when John asks for pics just reply that you don't need pics to prove anything to him. For a long time I tried to get John to show his 100 on a "hard core" trail (something other than rutted out roads for gay flex pics) and he never produced any saying that he didn't have to prove it to me.
I think the most important thing in this thread is something that Christo brought up a while back but didn't get much attention. He was talking about the ShortBus and how it isn't a ramp champ, but it is a lot more stable than a lot of vehicles that can crawl all the way to the top. In real world off-roading, this is what you want........balanced travel between the front and rear. You can make a 100 flex like mad in the back, but you will lose stability. John will argue this and say that his real world results disprove my point, but I still have yet to see any of his pics showing real world off-roading. If you are on relatively flat ground, yes, the rear axle will follow the ruts very nicely, all tires will stay planted, and you can get out of your car and take hundreds of retarded "look, the back can flex but the front can't do schmidt." Take that same vehicle onto a trail that has lots of off camber situations coupled with flexing the suspension at the same time, and all that rear travel will get you into bad situations. You get too close to the roll axis, and just as you hit it, immediate transition to your side. A lot of D90 guys deal with this because the front end doesn't flex nearly as well as the rear. Some just build up the rear to flex ridiculously and they become topple machines.
Christo's point about stability doesn't refer to keeping all the tires on the ground. Sometimes a wheel up is more stable than ruining front to rear suspension balance.
Flame away.
DBS311 said:Yeah, pretty much what I expected from John.
When did I say I was the authority on the 100 series?
When did I attack the "shock" issue?
In fact, when did I even mention shocks?
Where did I say that your off-road ride sucked?
When did I say that a balanced suspension between the front and rear meant the EXACT same travel in inches?
Did I tell you which setup is superior on your truck??
Johnny boy, I could really care less what shocks you put on your truck. My point (besides flaming you a little) was that one (I'm not talking only 100 series owners when I say this) should try and maintain a balance between front and rear travel. When you start to have one end that moves A LOT more than the other, you can get yourself into bad situations. With radius arms on the front of my Bronco I run into the same problem that the 80 series guys experience. Now, I could be a moron and put a 1/4 elliptic setup on the rear of my truck that flexes nearly 90 degrees and topple on nearly every serious obstacle........Or I could use limiting straps and try to balance the articulation, lift a wheel from time to time, but be a lot more stable in the end.
Also, why is the ShortBus exempt from my example? You can't tell me the laws of physics don't apply to Christo's truck. I would also consider my Bronco a "whole nother truck with unique build and huge tires" but I follow the same rules and concepts when building it and my 62.
Dude, I know you are like 75, but try and calm down a little. You show the early signs of frustration that accompany ED.
Oh, and judging by your signature, you must not have much off-road experience.
DBS311 said:Hey ATS4x4, when John asks for pics just reply that you don't need pics to prove anything to him. For a long time I tried to get John to show his 100 on a "hard core" trail (something other than rutted out roads for gay flex pics) and he never produced any saying that he didn't have to prove it to me. Flame away.
ats4x4dotcom said:Our standard shock package is slightly longer than what John has achieved, and my original point here was always, just to let John know he didnt really save the 100 IFS world, but that he expected everyone else to be as surprised as him, when he did it, because he hadnt seen it in his world before.
I think most of us knowJohn
well enough when he is behind the computer, to take what he says as his opinion
ShottsUZJ100 said:Tell us about your standard longer shock package for the UZJ100? What front shocks do you use that are longer and how much long are they?
spressomon said:Not being an expert at this...I'll just get that one out in the open right up front...but isn't the limiting down travel of the 2.5"/2/75" raised front 100 IFS the A-arm bump stops and not the shock? So what value would longer front shocks have with the stock A-arm assembly?
ats4x4dotcom said:The shock is the down travel limiter, so longer shock = more down travel.
spressomon said:I thought, with a properly set up suspension, using the shock as the 'limiter' was not good for the shock?
ats4x4dotcom said:Correct.
Toyota chose to do it anyway, so we designed a shock, and bush/rubber set up to cope with that.
spressomon said:Next question: Are they available to us here in the USA? And what, if any, downsides to your set-up?
ats4x4dotcom said:You havent read this thread very well have you John, maybe more time reading, less time attachingposer
pics.....
