Apparently not...Those people tend to be smart enough to not post anymore![]()
Thanks!69293-12040
Or aftermarket
https://www.amazon.com/gp/product/B0040D0L02/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
69293-12040
Or aftermarket
Reviving any oldy but goody. Hatch stopped working from the outside and discovered this as the culprit. I have a landscaping wire temp fix in place but doubt it will last another thirty years.Update, received replacement "not oem but substitute" piece from CDAN yesterday, plug and play today, problem solved.
Saying thank you for this masterful idea! After 2 years , I can open my tailgate from the outside. I ended up adding two nylon washers on each side of the bolt to prevent metal on metal and lubed it with some bike grease. Thanks mate!I fixed it using a 4-40 x 3/4" machine screw. I tighten one nut all the way to the head. Then pushed it through where the black plastic piece was. Then I put some blue Locktite on the exposed threads and put three nuts on which covered the threads. I would've used a nylon lock nut but couldn't find one that small. This gives the latch something to "push". I didn't tighten the nuts all the way down, leaving some play. Works like a champ. I'm actually quite impressed with myself!I meant to take some pics but forgot until I got it installed for the 6th time. So here is a pic after its installed.
You can see the silver of the screw and nuts.
Thanks everyone for your help and input! I really appreciate it.
