EarthX
Owner of Earth Exploration Technologies
Does anyone know if it is possible to swap a high pinion third out of an 94 fj80 into a front axle of a '85 fj80?
Mor4wd said:So then maybe you can? What other parts are needed?
Mor4wd said:Well my problem is the I have a 350 with a supercharger and an automatic transmition. And due to the height and flex I need a double cardon front shaft. But becasue the tight space near the automatic tranny I can only fit a very small double, and that keeps snaping.
Dynosoar said:Run the cardin shaft with the double at the pinion insted of the transfer case. (I do this with a V-8 350 and a turbo 400)
ridgerunner said:How does that cancel out the movement of the tansfercase u-joint?
My understanding of the theory behind the double cardon was that the pinion had a regular ujoint pointed directly at the transfer (and therefore no real movement) and the double cardon at the transfer then cancels itself out, giving no vibration. By switching the shaft around, you have one u-joint operating at a steep angle and no angle at the pinion ujoint, causing vibration at the transfercase end. There simply wouldn't be any need for a double cardon at the pinion. I apologize for lack of technical terms.
Mor4wd said:I think you are right on. That would solve my clearence issue BUT I would loose the flex of the double cardon.
My drive shafts were built by tom woods(whom Ill never use again) But i belive the are a 1350? Does that sound right?
ridgerunner said:So is your thinking of using the high pinion diff that you could use a regular shaft and get rid of the double cardan?
1350 sounds right. Personally, I think I would call Jesse at Highangle to see if he could do any better than Tom Woods.
