Fj62 where should oil pressure be on gauge at idle?
Bay Area
Fj62, I check oil level and appears to be on the high side.
However the gauge at idle seems a little low from what I’m used to since I did and oil change a week ago.
Curious where it should sit. It just crosses over the midway line at 75-80mph and 2.8k-3k rpm.
That looks good. It's about where mine sits. Usually it'll be right on that middle line at cruising RPMs.
Mine sits on the first line on a warm day. If you really need to know get a mechanical gauge and see where it really sits.
the gauges are never 100% accurate; usually when driving the needle is higher than when idling. the rest depends on how thin the oil gets when hot. mine varies between the 2nd and 3rd lines (where the third line is the middle)
