fj62 / 3fe cooling hose diagram ?
@mblakec - for my rear heater I have all hoses intact except the hard lines off the firewall are missing flexible hoses 87255B & 87256B. I have no idea where they're supposed to connect up to so they can bring coolant in/out to the rear heater. Do you know? I wonder if PO did a sloppy delete. I purchased over the summer and shipped up to Boston from TN so guessing the PO had no need for rear heat. It would be great to get the rear heater pumping since the front heat isn't strong enough to warm the entire cabin at cold temps.
Hi @mabbet, I traced the connection to the rear heater supply return with the red and green lines. You’ll see one connects to a hard pipe by the motor and the other connects to a tee.
Another slightly related thought, I found my heater was barely putting out heat when I first got mine. After replacing the thermostat I get nice toasty heat. It wasn’t ever letting the motor warm up.
@mblakec Ok, that makes sense now. The PO removed the T pipe and replaced it with a U pipe. Do you happen to know the part # for the t pipe? One more question, why would the PO bypass the rear heat? I wonder if there is a clogged pipe so wasn't pumping heat. I will try to flush the rear lines today and see if water flows in/out. Thanks!
@mblakec One second look I still have the t pipe but PO ran the hose from the t pipe to the engine to bypass rear heater. If the lines flush out today, I should be able to reconnect pretty easily, right? Looks like I need to buy hoses 19 & 20 from your "D" diagram. Can you confirm? Thanks!
Yep, you just need 19 and 20. That’s nice that the T is still there.
Some people bypass the rear heater just so that they have less potential points of failure. I think that’s most likely. Good idea regardless to flush everything though.
@mblakec I flushed out the lines and now I know why he bypasses. The hardlines from the rear heater core are corroded and leaking. Part # 87208A. Did you have to replace that part as well?
@ToyotaMatt do you carry part# toyota 87208A?
Now I see 87208A
This is a 87208A from a 60 Series ….
I am 💯 % certain of this ..
It is the correct 13mm OD rear heater tubing and will use a M8 bolt / faster
Let me know if you require any additional Tech
I have had this for maybe close to 15 + years
NOS / zero corrosion or flaws to report …
Matt
Bummer. I didn’t have to replace my hard lines, so I haven’t tried sourcing them. Hopefully ToyotaMatt can get you straightened out.
This is a 87208A from a 8/80 - 1/90
60 Series ….
I do not know what model BJ6# FJ6# or HJ6# it applies to …?
Let me know if you require any additional Tech Metric Measurements etc ..
I have had this 87208A for maybe close to 15 + years approaching 2 decades
I can compare it to my 5/89 Canada Spec. FJ62LG-PNEK in a hour or
So if this helps here ?
Matt
View attachment 3732353View attachment 3732354View attachment 3732355View attachment 3732356View attachment 3732357View attachment 3732358View attachment 3732359View attachment 3732360View attachment 3732361View attachment 3732362
@ToyotaMatt that looks like the piece See the picture below.
i concur a solid current-fitment match visually as well ...
what say you ......?
the SNIPER Trigger pulling method while letting out a good volume inhale of air was derived from the first hand held portable Glass Slide Photography that made tremendous leaps in fundamental technology during the American Civil War
April 12, 1861 – April 9, 1865
i sent you a PM , please check your in-box
thanks
@ToyotaMatt I'm getting 150mm too. It's dark here in Boston but i measured center to center on the bolt heads and shows 150 mm. See below.
Jumping in and hoping that the hive can help me out. I can’t find these on any of the diagrams in this thread. It is for a non-US spec FJ62 with a 3F engine. No rear heat.
Does anyone have any thoughts or philosophical insights on what p/n OEM or Gates these might be?
Post in thread 'FJ62 - Heater Hose Kit Complete ?'
FJ62 - Heater Hose Kit Complete ? - https://forum.ih8mud.com/threads/fj62-heater-hose-kit-complete.1334796/post-15405126
Right hose - Toyota 8724590A27
Upper left - Toyota 8724514500 (cut to fit)
Lower left - I’m not sure on this one as I have rear heat and that one is different as a result.
I had trouble sourcing those hoses, so I ended up just cutting to fit. It's been a good winter with hot water flowing to the front and rear cores. Now, on to the starter... it never ends, but I wouldn't trade the old girl for anything else.
I just finished replacing the coolant and heater hoses on my FJ62 with rear heater. Finding them all was a bit of an adventure, so I thought I would share the complete list that I used here. I prioritized ordering the OEM hoses from Toyota where they are still available and then used alternates from Gates when they were not. The only two I didn't do were the ones connected to the expansion tank. Thanks go to lots of different folks on Mud for posting their gates alternates. View attachment 3658849
Diagram A
Diagram B
Diagram CView attachment 3658860
Diagram D
What is the full part number for the single upper radiator to thermostat housing hose clamps and the two lower hoses' clamps? I see "16571A" and "16572A" but that's not a full P/N.
What is the full part number for the single upper radiator to thermostat housing hose, and the two lower hoses? I see "16571A" and "16572A" but that's not a full P/N.
In the table at the top of post 16, I listed the full part number next to the “diagram part number”. I don’t know why they don’t just put the actual part number in the diagram. Sure would make things easier.
