Here's my issue with my newly rebuilt engine. Just about everything in the engine is new or rebuilt (new radiator, fan clutch & water pump)
I noticed that after a while the temp gauge needle goes up to almost the red area. I took it back to the shop who did the work and had pressure testing done. Had the water pump checked again and checked all hoses for leaks. Everything seems to be just fine.
The engine temperature all around the engine (running) stays normal under 190 degrees. We replaced the thermostat sensor with factory sensor without any luck.
Anyone have a clue as to what to do? It's so frustrating!
