Hello,
1987 FJ60 stock rear axle. Diff breather is in stock location and has evidence of leaking oil. Here is the timetable:
I have the following questions:
- About 2 months ago I opened the rear diff fill plug to check the fluid level. Fluid was at the fill hole and clear amber in color.
- About 2 weeks ago I went wheeling and did a fair amount of driving through the water. Nothing crazy, no water inside the truck or anything. Deep enough to get water in my distributor and make it unhappy.
- Today, for unrelated reasons, I changed the rear diff oil. Prior to doing this change, the truck had been driven for a few miles. When the fill plug was removed (drain plug not removed yet), oil immediately came out the fill hole, meaning the liquid was above the fill hole.. When it came out, the oil was forest green, not milky white green. Drain plug is boogered, so I used a pump to remove the old oil through the fill hole.
- While I was under the truck, I noticed that the diff breather was moist from the top (at the breather) all the way back down to the axle. The breather itself was black and crusty.
- No oil is leaking at either rear hub at this time.
- Do I need to do anything to my breather, like replace it?
- Could this just have been water ingress from the breather?
- If the hub seals are going and they are the source of the water, wouldn't there be diff oil leaking out at the hubs?
