FJ60 Door Panels: Customizable and Affordable (2 Viewers)
Same price. Per Luis's reco I ordered the manual ABS version and wrote in the order notes that they were for a US spec 62 with electric windows.
I received them in the mail today and the cuts look spot on.
Did you order through eBay or from his website
Thanks
I finally installed mine and am very happy with the results. I ended up adding 6.5" component speakers while I was at it, along with a new master window switch.
Sprayed all the gray pieces in the vinyl/plastic paint that someone mentioned, and reused the window trim off of the factory door cards. Since I had each door apart, I also took the opportunity to replace the door handle bumpers, as mentioned in NCFJ's "Warhorse" thread.
I also added some sound Insulation to the inside of each panel to cut down on noise and rattling. Amazon sells 18 Square Feet of it in 150mil thickness for $30, which was the exact amount needed to cover each panel. It is about 1/8" thick. Noico Sound Insulation. I already have the metal faced version on the inside of the door, so between the two it cuts down on a lot of noise.
I also took a page out of @Comet 's book from post #104 and did the rivnuts as well (excellent tool, by the way - I hadn't heard of such a thing before reading this thread).
Only thing left to do is replace the plastic vapor barriers.
For the other odds and ends:
Window felt- just ordered a set of the exterior felt. i ended up drilling out holes on the inside so the clips would clip exactly like the outside. Ill post pics when i do the rear doors if anyone is interested.
Lock Trim- ordered 4 more of the OEM rear hatch door lock trim.
Arm Rest- painted with VHT satin black vinyl dye, matches perfect
Inside Door lever trim and window crank- ordered black from @Cruiser Corps
Now that i have this done I'm excited to finally get the rest of my interior, including my inclinometer and some other clean up pieces installed.
View attachment 1906267View attachment 1906268
Anyone have the part number for the black inside door lever trim? Cruiser Corp does not seem to have any more.
Need to confirm this with someone who knows better then me but I believe it's this...
69277A
69277-16040-23
Bezel, Door Inside Handle
[08.1987 - 01.1990] BJ60,FJ62,HJ60..SOB..(GX,VX) GRAY,TRIM1#
Japanese Warehouse
5...7 business days
US $8.88
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899
UAE Warehouse
4...7 business days
US $9.47
Average handling time
69277A
69277-16040-36
Bezel, Back Door Inside Handle
[08.1987 - 01.1990] BJ60,FJ62,HJ60..SOB SEPIA BROWN,TRIM4#
Japanese Warehouse
5...7 business days
US $8.82
UAE Warehouse
4...7 business days
US $9.47
Anyone spray paint these brown to match the brown interior rather than changing everything to black?
And what is the part number for the standalone inner weather strip needed with these door panels?
59034682285__305478c7-368b-421f-a79a-64f3f49f8819-jpeg.2110603
This paint is amazing
I was thinking the same yesterday. I want to get a set of the cargo panels and spray brown
Just worry about chipping/scratching in the rear cargo area. Would be great if someone had some first hand experience with brown paint.
Got an email from Luis at Australian Door Cards last night. He said that they have been working with their ABS supplier and hoped to have the full FJ60 kit in brown ABS early next year (January possibly).
guess no one has gone down the spray paint route...
Will wait to see if they can source the brown ABS panels in early 2019
