Wanted FJ45LV / FJ25 / Early FJ40 Parts for FJ28L Restoration
scoobiedubes
Phoenix, AZ
I decided maybe it would be best if I just create one ad for parts, and edit as we get into this restoration and things need to be added. Here's the parts I'm looking for right now. I understand many of these will be quite difficult to get and I may have to find other solutions, but can't hurt to ask.
STILL NEED:
  • Early / FJ25 Fog Switch
  • FJ25 PTO & Winch (pipe dream)
  • FJ25 FHT door window hardware
FOUND:
  • FJ25 horn relay
  • FJ25 fuel cap (either type)
  • FJ25 Flasher relay
  • FJ25/Early FJ40 bifold rear door
  • FJ25 column turn signal switch
  • Early ~1960 F135 engine - as close to engine # F12XXXX as possible
  • Early tool roll & tools
  • FJ25 wheels
  • FJ25 E-brake lever or entire trans (I now have 3 partial transmissions, so I hope I can make one complete one)
  • rk30-91100 bottle jack
  • Vacuum wiper motor, Asahi
  • Early Denso clamshell heater
  • FJ45LV bug catcher window (driver side)
  • FJ45LV door lock mechanisms
  • FJ25 shift knobs
  • FJ25 Dash turn signal switch - found, but need the knob
  • Early jack hook & extension
  • Early jack handle storage clips x6
  • Mid-1960s cast door pulls, or LV door pulls
  • Possibly set of 4 FJ55 door lock/latch assemblies with strikers
  • Early Fan Shroud
  • Dual matic 6 spline locking hubs
  • Early Rear view mirrors (inside & out)
  • Early FJ40 Generator
  • Cast or tin style clutch and brake cylinders
  • Vader light and switch
  • Early fender aprons (1960)
Apologies that some of these were posted earlier, just trying to clean up the list and post a single rather than several posts.
Here's the build thread for anyone late to the party
Here you go.
I have the hubs; VM me at the shop to follow up.
I decided maybe it would be best if I just create one ad for parts, and edit as we get into this restoration and things need to be added. Here's the parts I'm looking for right now. I understand many of these will be quite difficult to get and we may have to find other solutions, but can't hurt to ask.
STILL NEED:
  • Early F135 engine - as close to engine # F12XXXX as possible
  • rk30-91100 jack
  • FJ25 turn signal switch
  • FJ25 Shift knobs
  • FJ25 wheels
  • Vader light and switch :censor:
FOUND:
  • Early Fan Shroud
You don’t want to run lockout hubs with a 25 transfer case. The case is lubricated by the front drive shaft spinning the front output gear which in turn slings oil through the rest of the transfer case.
I thought i had seen 25s with the dualmatic hubs as a dealer add-on?
Updated the list, found a few parts in the last few days - making good progress! Thinking the toughest thing to find now might be the e-brake assembly or just an FJ25 transmission. Any ideas welcome, anything that might be a suitable replacement (with the existing transmission, I don't want to go with a non-FJ25 trans), etc.
Bump, haven’t updated this in a while. Have found quite a few pieces but still looking for some. Added the PTO & Winch which I know is a pipe dream but can’t hurt to ask, as well as the flasher.
STILL NEED:
  • FJ25 E-brake lever or entire trans (I think I might have enough pieces to put this all back together now, but if a complete one came along I'd still be interested in it)
  • PTO & Winch (pipe dream)
FOUND:
  • FJ25 wheels
  • FJ25 shift knobs
  • Early Fan Shroud
Hello I have 2 PTO's factory Toyota winches .I have both slave decks ,both PTO drive units,
I have shift assemblies somewhere out there. Both slave decks have cables on them ,I have an assortment of driveshafts for above ,
These are both from 70's area cruisers if interests is there I will be glad start taking pictures of what I have, Thanks Dave
Dave, I’m looking for the FJ25 PTO - but I’ll PM you on the other pieces as I think they would work if I’m not able to find the nearly impossible to find single fairlead FJ25 version Thanks for the reply!
