FJ44BT Build
Started working on the engine mounts, I bought the engine side mounts unfinished and ended up cutting and rebuilding them, I probally salvaged 40% of the original mounts..not sure if it wouldn't have been easier to build from scratch. I am going with Generation I Dodge isolators. For the frame side I first fabricated a 5"x2" 3/8' reinforced mounting location, I then modified Gen I engine side mounts and reversed them attaching them to the frame.
A few photos showing transmission placement, No mods to sheetmetal will be required, also the pan is flush with the frame rails.
This is going to be a killer rig when done. Hopefully the mods they made to the trans hold up because i've personally had horrible luck with 700r4's behind sbc's.
This tranny started with a stage 3 build (for a gasser its rated at 650 hp and 450ftlbs) It has a diesel gov & the valving is modified for the cummins 4bt power curve (full torque @ about 1850-2000 rpm) I alos have a low stall torque converter for drivability.
For regular use it should be fine. Hard offroading with wheel slip & spin will be the true test:eek:
My original plan was to install the new drivetrain suspension & steering then drive it until next winter. Then do a body off rebuild..well???? winter is coming in the southern hemisphere:grinpimp:
Actually the guy who bought my old engine and trans put me in touch with his painter and he has a slot open. So I stopped the enhine mounts to disassemble the body and get it off to the painter.
I have another week to pull and deliver the tub & sheetmetal.
Body is off to paint I hope to have the tub back by june first. In the mean time the list is getting longer ugh:crybaby:..A few photos of the chassi and drivetrain
Started on transmisson crossmember. I started with the AA crossmember ( great rock catcher if you collect rocks) and a couple pieces from roughstuff.
Well while the body is off to the painter and the frame is at powdercoating I started working on the rearend disc brake conversion.
The usual stuff remove the spyder shaft retaing bolt, drop out the spyders, remove the c-clips & pull the axles straight forward...that is until you find out the bolt has sheared sometime in the last 40 years.:mad:
The top bolts is what came out, the bottom bolt is what it should have looked like:hhmm:
So I drilled out the pin, not an easy task since you are drilling horizontally, I used 5 step drills the drove the pin out by shearing the remaining pin, the pin being harden steel helped. I still have to easy out the remaing bolt in the carrier and easy out a piece of the pin, what a PITA. The carrier threads are still ok :bounce:after I chse them with a tap
