- Thread starter
- #141
.Got my ford F250 shock towers in,got my lower shock mounts sorted and fitted the adjustable Ranchos the other day...but seems to be starving for fuel...spluttering and stalling once the carb secondarys are opening.
Changed fuel filter,checked small filter inside the weber,blew back through the fuel line..no change.
Maybe blocked jet i thought...went out to have another fiddle with it...jumped in,hit the key to start it,pressed the accelerator....and the throttle cable broke
Pulled the throttle out of another FJ40 (and future project),Pulled carb down,cleaned everything,and spent hours in the heat trying to fix it.
it ended up being a weak fuel pump..it would flow enough to work at idle/low revs,but wouldnt flow at higher revs/under load....new pump,shes like new again..and shocks that actually work are a great improvement
