Well it finally dried up enough and warmed up enough to get back under the car. The area I had chosen for the AN bulkhead fitting had plenty of clearance. Were I was out of luck was with the seat clearance to the top of the tank or more correctly stated the top of the new in tank fuel pump. I placed some 1/2" nyloc nuts, which measured about 5/8" tall, on the seat supports. That gave me plenty of clearance so I'll be fabricating some 1/2" spacers to keep the seat bottom off the top of the tank.
I also learned that assembling what Russell calls Twist-Lok fittings and hose is not a simple task without the proper tools. I tried to assemble the first fitting by just pushing the hose over the hose end barb fitting, NO F'N WAY!
After several attempts including the use of a hammer I was almost ready to spend the $200 plus dollars for this tool.
Then I figured maybe I could use my lathe/mill multi tool to accomplish the same thing. It worked! I used the 3-jaw lathe chuck to hold the hose. I then was able to push the hose end into the hose using the the lead screw to feed the tool post. I had to use a V-block I had for the 45 fittings but the straight fitting pushed straight in.
Now I just need to find a cap for the original tank feed line and plumb the rest of the fuel and vent lines.
I might get away with a 1/4" spacer if I were to trim all the screw thread protruding though the nyloc nuts holding in the pump top plate but figured the 1/2" isn't going to raise the seat noticeably and if I need to replace the pump for any reason the shorter studs could make the job more difficult.
The two new lines you see are the in and out lines. I'll be plumbing the vent line through the factory fuel supply grommet. Also, they fit nicely under the factory center console.
I forgot to mention but these are -6 AN fittings and although a 45 won't fit through the spindle of the lathe/mill straight fittings will. This means I'm good for building the rest of the lines as long as there is one straight fitting on the hose.
