Byron, I admit I'm not well versed in 3FE fuel injection, don't know what fuel pressure it requires, or if it uses a return line (primarily because I'm a V8 conversion guy). I do, however, go along with Flipper1938's idea about the under floorboard tank, and here's how a 22 gallon rear auxiliary tank may help you:
(1) greater fuel capacity (22 gallon).
(2) nylon tank, lab tested stronger than 14 gauge steel.
(3) nylon, no welded seams, won't rust.
(4) fuel pick-up tube easily converted for in-tank pump.
(5) has return line provision if needed.
(6) many times used as the one and only stand-alone tank, rids passenger compartment of fuel tank.
(7) availably from Marks Off Road or Tojo Products ebay store.
i bought a walbro external pump set at 9 psi for my 350 tbi. Going to be mounted in the frame with some thin rubber. I hope it wont be too noisy. Easy to change i guess.Looking forward to feedback about the pump. I'm most interested to know how loud it is, and if you can hear it while driving. I want to go the same route, but have had past issues with loud in tank pumps (walbro 190 and 255). Hoping this pump is quieter. I'd like to use it or similar for my setup.
Matt
Yeah thx suppose to be 9-16 or something i had to double check.
TBI operate in the "to be 9-16 or something" range, the multi port EFI operates in the "neighborhood of 50 - 60 PSI."
I have a 2FE with the Toyota pump in the stock '68 under the seat tank. Can't hear the pump after the engine starts.
Jerry D.
Can you take a photo of the entire top of the tank, so that the relative location of the new pump can be seen? What year tank is this?
Thanks.
Hopefully this will help:
Tank is for production date 12/72 (1973 model year) FJ-40. This is the second OEM tank for the vehicle as the original developed leaks so I replaced it with this back around 1986.
