Wanted FJ40 Engine hand crank handle & bumper bracket (2 Viewers)
Bakersfield, Ca
Looking for the manual engine crank handle and the bracket that mounts to the bumper (like the one in the photo)
Jason-
@foxfab who not around much did a run of those brackets years ago. If he still has any I don't know. The engine crank handle came in two different lengths. Late FJ55 and 45/47 came with the longer version which is also used to lower the spare tire. How those would store in a SWB I'm not sure.
I made my own handle for my FJ40, and made it it shorter than factory, because even with the bracket, I was bending the crank handle (at the bracket) while cranking the truck. Yes, you need to bit a bit of a he-man to crank start a '40, at least one with good compression.
Thank you. What’s the measurements I’m look g for?
Weber Sarge made a slew of the brackets about two tears back. He was working on repopping the handles and mounting clips but no developments since. You could try contacting him.
The add is for a fabbed crank and an original bracket. Seems over priced seeing as how I got my bracket at Specter for like $25. Now, an original crank AND mounting clips...,
I’ve been thinking about Kevin recently. I should give him a call.
My brackets are from foxfab.
That is @IDave in the video... love that he posted that
He hasn’t been on mud in like forever
I’m afraid IDave has passed into the realm of legend. I am also happy to say that I had a chance to meet Dave in his home in Idaho.
And yes Jason, I have put a bracket aside for you. I haven’t looked for the bulb socket, but you’re still a long way off from needing it.
Sounds good. Thanks a bunch Mark. I’ll just grab when I come down with the shroud. Thanks again.
Jason-
Good timing on this. I need the bumper bracket as well. Mark I'll give you a call on Monday.
@65swb45 had a few. He saved me one. I’m sure he has a few more. I think he has run of them from time to time.
Jason-
