Builds FJ 45 Extended Cab Custom Vehicle Build Finally Begins (3 Viewers)
4 Wire Grommet used in the Duct connector sleeve.
Quarter is for size reference.
Reinstalled the seat with an adjustment so the Wife can drive the rig.
Maybe I won't have to cartch a ride with Woody at SnT this year. :D
I also had to raise it 1 1/4" so she could see over the steering wheel.
Right...I see what youre saying. The higher that trans hump goes, the more difficult it is to run the seat cradle.
The route you took for the trans hump was the way I was originally gonna go with mine. Just and patch. However, the triple sticks made life difficult for that.
Looks great D'animal!
Found the problem with my rear brakes.
They have been my enemy for 7 months (SnT).
When I had a new SS Braided line made of the rear, the tip must have broke off. I had the tip of the alignment spindle inside the brake line. Impossible to bleed. it acted as a one way valve. You could blow air through it one way but not the other. :rolleyes:
I replaced the brake line end and took it for a test drive. The brakes work now. :D
Rebuilt the rear latch assy as needed.
Drilled out 6 broken bolts.
The "T" handle on the inside would not work with the roll cage so I made an "L" handle instead and removed the outer handle all together.
Bottom pic is if you were sticking your head in through the rear hatch.
Great catching up with you last night.
Something similar to this will look NIIIICCCEEEE over the bed :cool: :
To verify, I have measurements of 61.5" wide and 59.5" long - basket to have 6" sides - radius to match an FJ40 tub at rear and a tighter radius at the cab end. Right?
Just thinking....do you want to still be able to open the rear hatch with the rack on.....might be nice, but we'll have to shorten the basket to clear the opening radius of the hatch:
Also, you'll mount those struts so the basket lifts up from the driver's side, right? And....we need to figure out a mounting system for the rack that will allow you to have room for these tall boxes underneath, correct?
Let me know your thoughts....
Upgraded some brake components with a Marlin Brake Master and an 80 series booster. (Need to bleed the brakes again)
Installed the rear hatch window. Found out there are two sizes of glass depending on which gasket you have.
Installed the heater plumbing on the inside and finished up the duct work.
Installed the heater control valve and got some ideas on how to plumb it into the engine.
Now I can finish the wiring under the dash.
I like the idea of sleaving for the heater ductwork, what did you use for the 90?
I've gotten tired of buying the defroster hoses from sor only to have the 90's dry rot out within a year.
