- Thread starter
- #1,061
These little rubber mounts fit great.
Nice!!!
You know, with Hydro assist, you may wantt o think about making your PS pump one of the remote res styles.
Curious how you're going to do the lower hose. I had to make an adapter to get from the massive cummins port to the 60s radiator port.
The top radiator hose, I used the GATES Part # 21729.
I will be installing a metal pipe in the center so I can shorten the hose. The bends and sizes are perfect.
I have some clearance issue that I do not like.
I like the way the hose lays since it allows easy access to the secondary oil fill tube. I have the #1 valve cover for oil fill as a primary.
It is too close to the fan. I will be having fan clutch spacer made to set the fan 30mm further into the housing. This will give me the clearance for the hose and should make the fan work more effectively and protect it from water crossing, etc.
