Builds FJ 45 Extended Cab Custom Vehicle Build Finally Begins (4 Viewers)
The Kaymar Accesories look pretty darned good as well. :D
Sorry, I don't have a Power Tank. :doh:
Fire Extinguisher is just for the pictures. Other why's you could not see it since I have so much junk in the back ground:D
Dude, that thing's higher than Tommy Chong. Those 35s look tiny. Spring under is definitely a good idea.
We all know that 38s would be the way to go...
BTW I really like the body work you have done. I always thought an extended cab 45 would be bitchin.
38's for sure....the 45/80 looks great with 40's
you talking bout Gary's truck?
if so i would agree it is a very nice truck i got to check it out in person right before butch sent a shock through the radiator after gettin some air:doh:
Once I get the rest of the motor and components in the engine compartment and a winch winch on the front it should drop a couple of inches. If that is not low enough, I will put shorter shackles on the front and rear.
Looks pretty nice .. I thought you gonna lower it a few inches .. coz you have plenty of space ..
Yes, Gary's truck. probably my fav LC.
Have the flat bed designed.
I Just have to find some one who can weld aluminum.
Just bring it over and I'll weld it for you. It's only a 14 hour drive...
It's about 10 degrees right now. I will be in turlock in march and I could weld it then if you don't already have it done.
If you are that clsoe you should plan to come by and see it. I'm a very easy 2 hour drive from Tulock and live jsut outside of the Sequioa National Forest. You can crash at my place overnight.
Yes, I'm serious.
