Builds Fix'n up the Land Cruiser..... (1 Viewer)
Started Transgo shift kit surgery. I will hopefully finish this on Monday. I used the thread here to aid in the process: A343 Transgo Reprogram Kit Install - 1995-1997 - https://forum.ih8mud.com/threads/a343-transgo-reprogram-kit-install-1995-1997.731930/
A little progress today. I was swamped at work so not much time. Take note of instructions having one bolt mislabeled. If you are paying attention to the sizes you will know. Size A not C.
Swapped and removed springs..
I removed one ball from the upper body and one from lower body. The pressure spring pictured below is removed from the valve body and replaced with one in the kit. It is located in the second picture and retained by a removable tab. The tab can be removed vertically once you depress the pressure assembly with your finger towards the valve body.
Holes drilled in plate for "truck" setting and new gaskets installed.
All back together and..........I forgot my torque wrench at home lol. Going to clean up gasket materials and pan in the time being...
Bolts torqued, 84 inch pounds.
Case cleaned.
Accumulators in and make sure you reattach the throttle cable to the cam on the right...
Make sure check ball and other springs are in place. Carefully balanced and put into place solo is fun. 😊
Make sure this pin is indexed.
Filter in, 84 inch pounds and oil pipe pushed into place.
FIPG applied per FSM and pan bolts set to 65 inch pounds.
New O-ring for transmission dipstick tube.
Paul, looks like u gettin ready for a turbo?...
I hope so.... Purchased 2 years ago, but needs CARB cert. I'll cross that road when I get there.
Nice!...Grade 8 Paul?
10.9
Look at my truck, no body damage and it's only used for wheeling. Heck I don't even have a skidplate! Still rocking the original!
Same. Odds are against us/me lol...
