Can an 80 series non turbo diesel engines bottom end be beefed up so a turbo can be retrofitted , so it is reliable and doesnt blow up?
Gday Mate, thanks for that info. What you have told me make's sense. The bottom ends would surely be the same between turbo and non turbo variants? Maybe turbo charging wont be such a good idea beacause i have a 2 tonne boat that i want to tow. Maybe i should stick with extractors and straight through exhaust. Cheers MateThe bottom end will be fine - you're more likely to have problems with pistons/ring lands and so-on before you break anything down the bottom.
If you are looking for your 1HZ to make decent reliable power, get a Gturbo Grunter Extreme kit from @gbentink GTurbo™ - Engineered Diesel Performance - Don't be scared of the sort of boost they run, the tune makes or breaks a diesel.
If I may ask, what are your goals/reasons for turbocharging? If you're looking for a bit more power day to day, go for it, but the Indirect-injection design of the 1HZ seems to lead to difficulties keeping it cool if you plan to work it hard towing or something like that.
The block and cranks are the same between 1HZ and 1HD-T , I think conrods are different, pistons are different, head is different, different pump and injectors. Not sure on other diffences.Gday Mate, thanks for that info. What you have told me make's sense. The bottom ends would surely be the same between turbo and non turbo variants? Maybe turbo charging wont be such a good idea beacause i have a 2 tonne boat that i want to tow. Maybe i should stick with extractors and straight through exhaust. Cheers Mate
