1990 FJ62... AC not working, compressor not firing. Pressed the schrader valves on the compressor and nothing came out. Suspect the system has simply leaked out over time with age and extended periods of not being used. Still (was) running r12.
Considering having a shop draw down the system as is, recharge it and see what happens. If it holds, great, if not then the fun begins....OR...(since the system may leak out anyway)...should I skip that and just start planning to convert to 134a?? I want to do most of the wrench turning conversion work myself then have a shop gas the system. Searched and read a ton...will call Coolstream for parts.
Questions:
- I really want to pull the evaporator to clean 27 years of crud out, guessing I should replace the expansion valve while I'm there? Anything else while I have it out?
- How many o-rings are in the system? ...and where are all of them? I can see most of the pipe/hose junctions, just wondering if there are any o-rings that are not obvious.
- Should I pull the compressor to drain the old oil? Or can the shop flush the compressor without removing it?
- Will replace the drier with a new 134a unit and replace schrader valves with 134a valves.
- Condensor...is there anything to do here other than replace o-rings? Flush? Shop flush?
- Flushing? Do the components need to be flushed out individually, or can the shop flush the whole system at one time?? Trying to minimize the shop turning any wrenches.
Anything else?
Did lots of reading, just some specifics that need some clarification. Thanks.
Questions:
Anything else?
