Question: When the comp clutch engaged there was no discernible engine idle up. Why is that? Is there something else that triggers engine idle up other than clutch engagement?
There should be a vacuum switch (VSV) on the driver's side fender, it is connected to the idle up actuator on your carb. Check to see that it's in place and the vacuum lines connected. There is also an electrical connection to it as well. It is controlled by the AC switch and AC amplifier under the dash.
The FSM shows these components and how to test if they are functioning. Go through them step by step to ensure they are functioning properly.
Thanks, but it's a 3FE...no carb. I'm sure same principles apply. I'll run thru the FSM.
For me it was an easy decision to go to r134 because it is nearly impossible to find r12 on my small island. Plus, if you are doing the work yourself or at home, it is much easier and cheaper to get the small r134 cans to test the system and refill with the free loaner gauges from the parts store. At least that has been my experience here in Hawaii.What I find interesting is the folks who stay w/ 12 to those who swap to 134.
What’s the reasoning behind the two different groups?
