Have a great trip. I went SF Bay Area to Boston and back in mine with no problems. Longest day was 950 miles with no problem. Do oil change, brake check, fluids and go. Post up tripmmI will be driving March 4th-6th.
Unfortunately I will not have time to replace the radiator. I had planned on taking the I-40 route, stopping in Memphis, TN, and Amarillo, TX. The other option is I-40 and I-20, as this goes through the lower southern states like Mississippi and Louisiana ( I would stop in Jackson instead of Memphis). What do you recommend, they both are approximately 33 hours. The second option is 30 miles longer.I PCS'd from CT to WA a few years ago and towed a fully loaded 5x8 cargo trailer mostly along the I-90 route. It was all fine until I hit the mountains and the 20+ year old heater hoses started causing problems. The skinny, head to block hose that runs vertically through the intake was the main culprit and one that rarely gets talked about here. Taking a more southern route should help though if you don't have time to go through these tricky heater hoses.
Also, the stock radiator is a really well built unit, but it is not efficient enough to keep the engine cool when hauling 5000 lbs at US freeway speeds. If you are on the original radiator, I would replace it with a far inferior quality, but immensely more efficient unit if you have the time (TYC).
If you don't have time to go through all of this, I'd be looking for the most flat route possible and taking it slow. Also, try to find out what the empty weight of that Uhaul is, they tend be a but heavy.
I hope this works - front brake section of the factory service manualMorning everyone,
Currently replacing the front brakes on the cruiser. Encountered a road block, if you would call it that.
My buddy and I don't know if we need to remove these bolts to actually remove the brakes. Essentially, we don't know where to go from here. He's more experienced with replacing brakes, and he just wants to make sure that removing these wont cause any sort of spring or something to fly out at him. Since we are on the topic, is there anything else we need to know before continuing with the brake job? Thanks everyone.
Do you mind shooting me some of those pics? I don't know if they are the same or different from @ChaseTruck .If you need a factory service manual I can upload some pics. Doing the front rotors requires removing the hub assembly. It's a fairly involved procedure if you haven't ever done them on one of these trucks.
I appreciate the advice. Feeling a lot more confident as I replace things like the tires and brakes (although we are having a hell of a time replacing the front ones right now). I actually bought a DIN cupholder that folds in and out, and its comes with "free box". Pretty cheaply made and the holders themselves are really small, but it fits a redbull can perfectly, which is my poison of choice anyways.I just did that drive last June with my '96 LX450. Going from Jacksonville to Lake Tahoe via Houston, CO, Southern UT (Zion, Bryce) then across NV. I will leave the mechanical points to the pro's here, but I do agree with an earlier point that if you are concerned about something then get it fixed. I replaced most gaskets, brakes, hoses, etc. before the drive. It was an old car and the gaskets had mostly turned to hard packed dust. Brakes had 20% left but why not go with a new set (I see you are already changing them). My comments have to do with comfort. Buy one of the WeatherTech Cup Phone cell phone holders then put it in the slide out cup holder. Great place to put you phone with google maps. Buy one of those 3D printed cup holders on Etsy (80 Series Double Cup Holder | Etsy - https://www.etsy.com/listing/193139438/80-series-double-cup-holder?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=fj80&ref=sr_gallery-1-3&from_market_listing_grid_organic=1&frs=1&bes=1&col=1). You can never have enough cup holders and the LC essentially has none. Finally, think about an arm rest for the drive. I used my wife's yoga block or you can use a pillow. But you need something because your right arm will get sore. No need to carry gas but do fill-up at 1/3 tank as these cars really burn gas. Have a great time.
Getting the cones to pop out is sometimes challenging. I've always tapped the end of the stud with a drift and hammer. Just be careful not to slip and damage the stud.
You can download the FSM from the resources tab above.I appreciate the advice. Feeling a lot more confident as I replace things like the tires and brakes (although we are having a hell of a time replacing the front ones right now). I actually bought a DIN cupholder that folds in and out, and its comes with "free box". Pretty cheaply made and the holders themselves are really small, but it fits a redbull can perfectly, which is my poison of choice anyways.
