NLXTACY
Wits' End
- Thread starter
- #381
Just ordered up a pair of BHMMAPPING's rear lower shock protectors: https://forum.ih8mud.com/merchandise-storefront/434037-80-series-rear-lower-shock-mount-guard.html
I highly recommend purchasing a lifetime alignment from Firestone. It pays for itself after the second time.
Few more for posterity
FWIW, on the Nitrocharger Sport, ARB does state that they do need some miles to "break in". So I would give it a little more before you decide if you like them or not. Also what tire pressure where you running on the washboards?
thanks Joey! Just an FYI, they are designed so that you use the factory bolt as a centering aid by sliding it down through the center of the press tool and into the bushing.
Will that press tool cover all of the control arm and panhard bushings?
No just the bushings at axle end of the control arms. Do to the way the bushings are designed the tool needs to be a slip fit in the arms bore so to make the most contact with the outer ring of the bushing. We've been talking about putting together whole kits for the entire truck but decided we would see how this one was received first.
