- Thread starter
- #61
Assembled Frankenstein filler
Nice - 1 day install!
I have fond memories of doing the same thing. if you do relo to the engine bay, reuse the existing hardline for canister fume burn off as the vent in, and then the only hoses needed are in the engine bay (much shorter).Cardboard mock-up of the charcoal canister. The extra flaps on one end show how much extra space is needed for the connections on that end.
Here are the places it definitely will not fit:
Hood won't close:
@lx200inAR I tried your idea of putting it where the resonator is. It would totally work there, and the side-exit exhaust could turn and immediately end before the tire and work fine, giving lots of room. This is super tempting. There is a problem, though.
The main problem with this approach is that the spare tire support bracket is in the way and would push the charcoal canister down too far. Think hitting your resonator on rocks is bad? Try hitting your canister on rocks.Still, I'm tempted to try to make it work somehow since all the connections are already back there.
This is how far the tire bracket would push down the canister (I've marked the bracket mounting holes), basically so the frame rail would no longer protect it.
I see two possible places in the engine bay. The first is on its side in front of the power steering reservoir, which would have to be relocated backwards an inch or so (I think that's what @grinchy did). The other is on top of the main fuse box, perpendicular to it. It appears to fully clear the hood when closed.
Yes, I had to cut quite a lot off the top of the part 51923A to get it to fit under the sub tank. The part is not structural (it's only a tube for the lowering rod to go thru). Easy work with an angle grinder.Learned that the spare tire stopper near the axle and the spare tire carrier guide are different part numbers when you have the subtank (since the tire sits lower). Also, there are two additional stoppers that attach the the spare support bracket itself. I think these last two stoppers likely make it so that bending the bar right behind the bumper is no longer necessary.
What about outside the rail behind the rear passenger tire (where AHC pump is on an LX), with a custom skid if it ends up partially below the rail?
I wouldn't recommend solid strand ethernet cable, get stranded if you must use it. I'd suggest a stranded 8 conductor, like this:@grinchy I see in your thread you used Ethernet cable to get the canister wiring to the front. Did you use a typical outdoor / weather / UV rated cable, or something even more durable? I was thinking something like this:
