Featured 100 - spressomon (1 Viewer)
These current sliders are the third incarnation. And I must say I am 100% pleased with them. I still have the prior version laying around. They only work with a 12mm or better body lift. And I think, after trying to reuse them, I need to reattach one of the arms; best fitted/done here. Might be easier for you to get Slee's sliders in the end.
The 2nd gen work fine but I wanted larger OD outer tubes and more outboard projection. The 2nd gen are OK but not 100% coverage like I have now.
so you've had 3 different sliders? Do you have pictures of the 2nd gen sliders? I'd like to see some pics for my ideas. Did you say your previous versions of your sliders only work with 12mm or more of body lift? Or were you referring to the 3rd gen?
They looked pretty much the same except were 1.75" tubing and didn't extend as far outward. Yes: My 2nd and now 3rd are built specifically for the 12mm body lift so that I get, well, 12mm more vertical clearance. I also use a flush lower mounting style so that no mounting hardware hangs below the bottom of the frame rail. Believe it or not I got hung up on the 1st gen hardware, which is basically the same as all the commercial fabbers use (for ease of installation).
I actually liked your first gen sliders for aesthetic reasons cos they looked somewhat oem. Did you toss those out? Cos I would be interested in them lol anything is better than my factory running boards:doh:
They work well for less severe application ;). Rusty_TLC has had them on his 100 for the past several years. The step feature is nice.
lol nothing is "less severe" than normal mall cruiser activity:frown:
Well if you ever decide to sell those 2nd gen sliders let me know. If they only work with the body lift, I might as well pick up the body lift from you too!:D
Let me dig the sliders out of the shed and see what would be involved to make them whole again. It would be best, assuming this is viable, for you to come here with your LC for the install.
I'll see what my schedule for spring break looks like just in case. If we do plan on the sliders, could you help me install a body lift as well?
I'm not cheap but I can be had :D
Looks killer Dan. I love the lower row of lights added. How many miles have you put on those tires and how are they holding up? I need to make a summer tire purchase soon.
J: I love the tires. Best so far of all the ones I've used. I have about 12k miles on them now and as you know they've been pretty tough miles with a majority with the KK in tow along with loads of on-trail miles. I'm really hard on tires (hmmm...common theme here :rolleyes:) and ultra critical so its a narrow lot of choices especially given my preferred size.
I don't know if I'm going to get them to 20k miles or not; might or might not. But either way I'll buy another set...I'm uber happy with them. And they're wearing WAY BETTER than the Toyo AT's I previously burned through (2-sets).
The only other tire, IMO, that I might be tempted to try (although they're not getting the praise on packed snow/ice compared to the GY Kevlar MT/R) assuming they became available in the 285-75R18 size I like is the BFG KM2.
Perfect, thanks..
No problem with that, I'd rather have you install and tweak my truck than have a shop do it. I'm pretty sure your probably more experienced than a majority of people when it comes to the 100 series:D
Hey Dan,
Even though you got around the problem, back in post 153 you mentioned Toyota don't sell the bushes for the control arms for the 100, I looked at the picture you posted, and correct me if I am wrong, but the bush shows a part number of 48702-60030, which is the same bush the 80 series uses, and are available for $34 ea. This may help others out who haven't ovalised their arms yet?
Hey Dan,
Warren: Yes for whatever reason one can buy the upper and lower rear control arm bushings for the 80-Series from Toyota. But not the 100-Series. The difference between the 80-Series and 100-Series rear control arm bushings: The 100-Series uses 14mm diameter bolts and the 80-Series uses 18mm diameter bolts. No one I've spoken to at Toyota dealerships knows why they changed to the smaller diameter bolts for the 100-Series. Maybe trips to the mall aren't as stressful on these bolts :lol:
While I'm here I thought I'd update the rear axle situation as of today. I've had to have the rear axles rebuilt a total of 4-times in the past 12-months. The first pair (left and right) were due to worn out/destroyed bearings (no visible outside leak that would have indicated seal failure). The next 2 rebuilds were performed due to blown seals: The outer seal, in both instances, were puking diff oil; clear sign of inner axle seal failure.
The axle housing may (or may not) be bent which might explain the 2 most recent axle seal failures. I have 3 flat spots on the bottom of the axle housing indicating at some time I hit something hard enough to crush it down. You think I'd remember such an event but nothing comes to recollection. Both coil spring perches on the axle housing are deformed/partially collapsed. Another indicator I bottomed out fairly hard at some time(s). To be fair the spring perches are not all that robust and wouldn't be that hard IMO to deform.
I checked the rear diff and locker breathers and they are all intact and fully breathing. I installed 1/4" rubber fuel line and extended the breathers to the engine compartment firewall years ago. I thought that would be an easy explanation for the inner axle seal failures...pressure differential during axle deep water crossings; I've done a few of those ;).
The design of the 100-Series all pressed together axle bearing assembly/system design leaves alot to be desired for someone like me that wants to be able to service the axle periodically. Stream crossings and axle deep mud eventually take its toll on any seal including outer axle seals. The tools to be able to do this at home would require 2 SST's (I do not know what they would cost to acquire or make...guessing at least $1,000) and at least a 40-ton press. Possible to do them at home with the proper tools and know how. Impossible to perform in the field if/when necessary. Additionally the parts necessary to do the job, as the parts really can't be re-used once pressed off the axle (ABS sensor might be able to be reused if not damaged apart of the removal process): $275 per side as a minimum for parts. And, again, there is no way to just inspect the bearing(s) without pressing the axle apart.
Whereas the 80 and 105 Series, et al, Land Cruisers came with full float style axles along with relatively easy to service bearings and hubs.
The 80-Series uses 30mm splined axles. The 105-Series, interestingly enough, uses 32mm spline axles of the same diameter as our 100-Series! And according to my parts source the brake rotor, caliper and e-brake drum brake assembly share the same part #'s between the 105 and IFS 100!
I've been rolling different solutions around for the past month or so including Ford 9", Dana 60 and 14-Bolt and/or complete axle assemblies from Dynatrac, SpyderTrax, Currie, etc.. All of these, with different advantages/disadvantages, have merit and would offer 35mm splined axles along with a more robust aftermarket/custom housing that would surely put any question of strength to rest.
But that direction would require figuring out how to deal with the u-joint difference and what to use for the brake assembly: Neither are insurmountable just add to the challenge and expense. There are a few different brake assemblies out there that use disc and drum combo. I'd just need to calculate/verify the volume difference of brake fluid required to determine if the Dodge/GM/Wilwood.
I'm in the process of determining the total cost of several different systems. The 105 parts including the axle housing are available from Japan4x4 (thanks Dave Stedman for doing all the leg work on this!!!). This might be the least expensive and least complicated overall. But I need to do a full comparison.
And I have several very knowledgeable LC and non-LC axle "experts" helping me with this project that I will be forever grateful to: Ali, Andy, Dave, Jack & Onur: Thank you!
Stay tuned!
I'm going to make a big guess and say a Tundra axle would need to be shortened first. Kinda like putting a Dana 60 under a Jeep, the track width is to wide in stock form. Again, a complete guess.
