- Thread starter
- #221
Just some quick thoughts...
Much of the difference in the WMS width may be due to the hub offset. If you could find a way to fit front 100 series FF hubs onto a 105 axle, the width would probably be much closer to the 68.x" you need. The problem there lies in that the 100 uses a larger inner wheel bearing to carry that offset... I believe it's too big for the 105 spindle. The bearing nut on the rear FF axles is also much larger than the front. Possible scenario if the 105 shafts are long enough and the 100 housing not too wide... machine up a couple 100 series style spindles that will bolt on to your existing rear axle. Front 100 hubs, adapt brakes... just brain storming....
This is a mini truck IFS vs solid axle hub. I'm speculating the 100 IFS vs 105 rear hub would be a similar picture.....
Interesting idea! I'll have to do some measuring to see if this would be viable. Good thoughts...keep them coming please!
GJ, even though I saw this all last week. So, I'll stop by next month, you can do the headliner speaker for me? KTHX!
